AFR Eliminator Race Intake Manifold for SBC
steve cowan
Re: AFR Eliminator Race Intake Manifold for SBC
Post by steve cowan »
1980RS wrote: Fri Dec 03, 2021 6:07 pm
steve cowan wrote: Fri Dec 03, 2021 1:51 am 20211024_112044.jpgI am a fan of the 300-25 as well
As per photo the as cast SV blocks off part of the runner,they need work
Do you think cutting back those long dividers might help that on the SV?
I layed these back,have not changed CSA of runners,carb pad matched to tapered spacer.
Want to try on my 383 with my 165cc (186cc) cast iron darts.
My theory is the bigger SV might keep the mach index down slightly to help engine not fall on its face above 6500rpm,but only a theory on my part. :D
ChopperScott
Post by ChopperScott »
Very impressive work. Anyone have experience porting the Team G 7531 with good results? Is it worth it?
Or maybe I'll just be the guinea pig, and take that AFR #4811PM for a test run.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
ChopperScott
I probably should have linked this in the original post, so here it is...
https://www.airflowresearch.com/sbc-eli ... -manifold/
...with "Partial Port Match", #4811PM
I'm going to call AFR this week to pick their brains.
1980RS
Post by 1980RS »
ChopperScott wrote: Sat Dec 04, 2021 8:02 pm Very impressive work. Anyone have experience porting the Team G 7531 with good results? Is it worth it?
Have a buddy that runs 10.0's@130mph with his unmodified Team G 7531.
steve cowan
1980RS wrote: Mon Dec 06, 2021 6:29 pm
I have one on those team G as cast with taller plenum,
Damn thing weighs a ton :D
steve cowan
Finished 300-25 today,
Got a new book as well :D
KnightEngines
Post by KnightEngines »
Looks good Steve, those old 300-25's with a bit of work are hard to beat on a 383.
ChopperScott
Speaking of a Team G 7531 on a 355...
ChopperScott
Here's the 434 with the SV2, and the 355 with the TG 7531, mentioned in the original post. Don't mind the rod poking through the oil pan on the 355. That's the top end I'd like to put on a 406... the Team G with AFR 220's, 65cc, competition ported, titanium retainers, Crower stainless roller rockers, and AFR stud girdles...
HQM383
Post by HQM383 »
So has anyone used or inspected or had any experience with the AFR manifold? They seem to be an enigma.
skinny z
Post by skinny z »
HQM383 wrote: Fri Dec 03, 2021 5:40 pm
SpeierRacingHeads wrote: Fri Dec 03, 2021 2:06 pm IMO, the Holley Dorton 300-110 is the best SBC manifold on the planet.
Is this out of the box?
I'll bump this for an answer from Speier.
Kevin
HQM383
Post by HQM383 »
skinny z wrote: Mon Mar 21, 2022 6:22 pm
Thanks.
With his enthusiasm toward them it maybe more than me that would like to know.
compguy
Post by compguy »
Did not try a Holley/Dorton ported, ran out of time to procure one and get it ported by a pro, but,
we tried four manifolds on a comp SB high RPM deal, a few years ago, on a known accurate dyno.
An Edelbrock Super Victor ported by Hogans, the GM bowtie ported by Hogans, AFR TFX composite and a fully fabricated Hogan manifold
The Edelbrock was the best.
ChopperScott
steve cowan wrote: Sat Dec 11, 2021 2:06 am
That extra weight leaves plenty of material for removal…
ChopperScott
