If I had that Eliminator manifold I would ELIMINATE the carb pad and runner extensions would be thinned down to get the area required for the engine/ application. Nice looking intake, reminds me of a SV from the outside.ChopperScott wrote: ↑Sun Nov 13, 2022 6:31 pm 0E455E98-44E4-4538-98FE-41912F53244A.jpeg
AFR Eliminator Race Intake Manifold for SBC
Re: AFR Eliminator Race Intake Manifold for SBC
I certainly don't have your skills in that department. Maybe I'll butcher one of my old Weiand intakes for practice... 7531, 7546, 8004, or 8016.steve cowan wrote: ↑Mon Nov 14, 2022 2:15 amIf I had that Eliminator manifold I would ELIMINATE the carb pad and runner extensions would be thinned down to get the area required for the engine/ application. Nice looking intake, reminds me of a SV from the outside.ChopperScott wrote: ↑Sun Nov 13, 2022 6:31 pm 0E455E98-44E4-4538-98FE-41912F53244A.jpeg
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
Steve,steve cowan wrote: ↑Mon Nov 14, 2022 2:15 amIf I had that Eliminator manifold I would ELIMINATE the carb pad and runner extensions would be thinned down to get the area required for the engine/ application. Nice looking intake, reminds me of a SV from the outside.ChopperScott wrote: ↑Sun Nov 13, 2022 6:31 pm 0E455E98-44E4-4538-98FE-41912F53244A.jpeg
What findings in testing would warrant AFR and other manifold manufacturers to put the cloverleaf and extended runners in their manifolds with this level of intended use? If they don’t put that extra material there they could be saving a buck.
I can't say why the clover leaf is cast in and what it is supposed to do but my opinion is -HQM383 wrote: ↑Mon Nov 14, 2022 2:00 pmSteve,steve cowan wrote: ↑Mon Nov 14, 2022 2:15 amIf I had that Eliminator manifold I would ELIMINATE the carb pad and runner extensions would be thinned down to get the area required for the engine/ application. Nice looking intake, reminds me of a SV from the outside.ChopperScott wrote: ↑Sun Nov 13, 2022 6:31 pm 0E455E98-44E4-4538-98FE-41912F53244A.jpeg
The extended runners are a good thing as it saves you welding.
I believe the plenum size and height helps dictate rpm if runners are sized According to application.
Anything I see that runs good has open plenum and shear plate or some form of mis - matched spacer to help with the reversion pulse on butterflies.
Again opinions may vary.
AFR makes a matched spacer for this manifold…
- New Member
Here's how mine end up
From a carburetor perspective the cloverleaf may be attempting to deal with the areas between throttle bores that can cause vortices. So maybe for a cleaner carb signal. Dividers, I can only imagine looking for length. I’m a believer that with each individual cylinder stroke the air/fuel filling that cylinder is coming from the manifold plenum and other runners. The carb is a restriction even at WOT v what’s already present in the manifold. So with the fill of each stroke the fuel destined for that cylinder is coming from wherever the straightest, easiest path is and not necessarily navigating corners directly from venturi to intake valve. The carburetor refills the manifold.steve cowan wrote: ↑Mon Nov 14, 2022 3:18 pmI can't say why the clover leaf is cast in and what it is supposed to do but my opinion is -HQM383 wrote: ↑Mon Nov 14, 2022 2:00 pmSteve,steve cowan wrote: ↑Mon Nov 14, 2022 2:15 am
So while a lot of people have gains cutting back or altering other ways I’m interested how some are so long due to the manufacturers development and some way back with their development. It’s an “it depends answer” but on what?
Maybe Schmittmotorworks can chime in and tell us. Correct me on my wild theory above too.
The clover leaf deal might of been the next big thing in the day but I heard Darin Morgan say they mill that out including the runner extensions and re- do the whole plenum arrangement again.HQM383 wrote: ↑Mon Nov 14, 2022 5:56 pmFrom a carburetor perspective the cloverleaf may be attempting to deal with the areas between throttle bores that can cause vortices. So maybe for a cleaner carb signal. Dividers, I can only imagine looking for length. I’m a believer that with each individual cylinder stroke the air/fuel filling that cylinder is coming from the manifold plenum and other runners. The carb is a restriction even at WOT v what’s already present in the manifold. So with the fill of each stroke the fuel destined for that cylinder is coming from wherever the straightest, easiest path is and not necessarily navigating corners directly from venturi to intake valve. The carburetor refills the manifold.steve cowan wrote: ↑Mon Nov 14, 2022 3:18 pmI can't say why the clover leaf is cast in and what it is supposed to do but my opinion is -
Same. I remember on a podcast I think he was saying the runners don’t need to be in the plenum, get them back out of there and similar to the cloverleaf. But I’m also mindful when listening to him he quite often lives in the 8000 rpm plus world. Brilliant information but constant “does that apply to me?”steve cowan wrote: ↑Mon Nov 14, 2022 7:57 pmThe clover leaf deal might of been the next big thing in the day but I heard Darin Morgan say they mill that out including the runner extensions and re- do the whole plenum arrangement again.HQM383 wrote: ↑Mon Nov 14, 2022 5:56 pmFrom a carburetor perspective the cloverleaf may be attempting to deal with the areas between throttle bores that can cause vortices. So maybe for a cleaner carb signal. Dividers, I can only imagine looking for length. I’m a believer that with each individual cylinder stroke the air/fuel filling that cylinder is coming from the manifold plenum and other runners. The carb is a restriction even at WOT v what’s already present in the manifold. So with the fill of each stroke the fuel destined for that cylinder is coming from wherever the straightest, easiest path is and not necessarily navigating corners directly from venturi to intake valve. The carburetor refills the manifold.steve cowan wrote: ↑Mon Nov 14, 2022 3:18 pm
Do you recall, as I don’t if he was talking specifically about the sub 7000 rpm guy?
Scott,ChopperScott wrote: ↑Sun Nov 13, 2022 6:31 pm 0E455E98-44E4-4538-98FE-41912F53244A.jpeg
Have you used that intake or know anyone that has ?
I remember he was on drag boss when he mentioned that,I think it was conversation he had with T bishoff at the time.HQM383 wrote: ↑Mon Nov 14, 2022 8:12 pmSame. I remember on a podcast I think he was saying the runners don’t need to be in the plenum, get them back out of there and similar to the cloverleaf. But I’m also mindful when listening to him he quite often lives in the 8000 rpm plus world. Brilliant information but constant “does that apply to me?”steve cowan wrote: ↑Mon Nov 14, 2022 7:57 pmThe clover leaf deal might of been the next big thing in the day but I heard Darin Morgan say they mill that out including the runner extensions and re- do the whole plenum arrangement again.HQM383 wrote: ↑Mon Nov 14, 2022 5:56 pm
I agree that what the people at DM level are not doing alot of stuff at our level,don't take everything they say as gospel for our junkers
Eric Weingartner got his hands on a 4811…steve cowan wrote: ↑Tue Nov 15, 2022 2:01 am Scott,
https://youtu.be/lhKskMAO-wQ
I haven’t used it yet, but thought I’d give it a try. I’m piecing parts together for the next build…
AFR 6901 intake gasket on the 4811PM manifold and 1110 220 comp ported heads…
I am going to test my S/V II intake next year on my 406 vs the 300-25 I have on the engine now. Best pass was a 10.65@124mph with the 300-25, but with some other new stuff on the car I hope to see 10.40's that would make my day with the junk I run
Looks like next year will be interesting then.
I have Dart block out at the moment, bigger cam,shaft rockers, smaller valve spring package.re- dyno
Then maybe more head work,new ported trickflow intake manifold. I am aiming for 10.0s @ 3600 pounds
