stepside drag truck
chevy art
stepside drag truck
Post by chevy art »
anyone ever hear of a stepside pickup truck getting air under the rear fenders at high speed and causing the truck to loose a little stability in the rear. my buddy is building one that wii go a maximum of about 125 mph and he says he needs to puts lots of louvers in the rear fenders to bleed off the air getting under the fenders that is causing the truck to get a little out of shape at the top end. is this true and is the louvers the solution. thanks Art in NY
lefty o
Re: stepside drag truck
Post by lefty o »
does your friend smoke things? #-o
BOOT
Post by BOOT »
Is the stepside wheelwell larger than a normal truck box or tubs?
The underside of a vehicle is the worst aerodynamic area.
discloseenjoin
Post by discloseenjoin »
Are you able to provide additional information that is more specific? cuphead
In-Tech
Post by In-Tech »
Design a diffuser in the back like a Ford GT and others. It's basically an upside down wing to pull down at speed and the diffuser part also helps to keep it straight at speed.
-Carl
Tom68
Post by Tom68 »
chevy art wrote: Thu Feb 10, 2022 2:02 pm anyone ever hear of a stepside pickup truck getting air under the rear fenders at high speed and causing the truck to loose a little stability in the rear. my buddy is building one that wii go a maximum of about 125 mph and he says he needs to puts lots of louvers in the rear fenders to bleed off the air getting under the fenders that is causing the truck to get a little out of shape at the top end. is this true and is the louvers the solution. thanks Art in NY
More likely their will be a vacuum under them, but that won't offset the vacuum pulling up on the pickup bed.
