3d fastcut CP cylinder head fixture
Jbird988
Post by Jbird988 »
Looking for 3d fast and preferably cp cylinder head fixture.
ProPower engines
Re: 3d fastcut CP cylinder head fixture
Post by ProPower engines »
Jbird988 wrote: Thu Jun 23, 2022 11:33 pm Looking for 3d fast and preferably cp cylinder head fixture.
What size of drivers do you want??
There is 3 different sizes of ball drivers available
What pilot size are you using??
There is several different choices but if you are just starting go with the .375" pilots as they are the easiest to get these days.
Call Cylinder Head Supply. They are the most well stocked on that tooling.
Goodson may have some but they are over priced. Personally I get tooling from CHS in Clackamas Oregon
Call CP motors directly and order a fixture from him. There is nothing on the market except to have a fixture built.
Jbird988
Post by Jbird988 »
Moving seat operations over to my mill. Preferably .375, standard body and would also be interested in the wide body. R8 drive adapter I would also be interested in.
Bossman
Post by Bossman »
R8 wide body what type of heads are you cutting?
ProPower engines
You are better off to buy them new.
The bodies do wear over time I know I replace them about every two years. The wide body driver is really large physically and will not work for import heads. I tried a few times being lazy and not wanting to set up another driver.
And also the size if the set screws is very important. The newan ball drivers are the same as the goodson and CHS drivers but I know there is a shortage of drivers at this time after covid ended as I tried to just buy a few and had to order them in.
Are you looking for HSS or carbide pilots??? I believe Rottler as a decent selection last time I got a couple special sizes for a job I took on that were odd ball sizes.
jake197000
Post by jake197000 »
I have Pete's fixture it is simple and sturdy,I really like it he's a clever guy
