transmission manifold pressure switch 4l60e
Hello, I am going to replace the solinoids in my transmission 4l60e 2011 silverado 148,000 miles and the manifold pressure switch, however never replaced this i know it has 6 bolts 2 different sizes what i dont know is the torques on the bolts for this and is there anything special when replacing this do i put it back on dry or wet when bolting it back up? thanks in advance. sorry forgot to add a link for what it looks like so here it is> https://www.transmissionpartsdistributo ... ct-reviews
Re: transmission manifold pressure switch 4l60e
11nM / 97 in lbs. "Dry" is a relative term. There will be so much ATF everywhere that truly dry will be an exercise in futility. Be careful with the tab on the connector; they live a hard life and can tend to break off.
thanks for the help. when i said dry i just meant if there was a special way to install it.
