New SBC heads
Re: New SBC heads
I'd let it set overnight... Can't believe you carved right thru the pushrod pinch already.. At least if there is a area that is easy to repair its the pinch area in the intake port. ,(stays cool when running)The biggest skill is keeping stuff even.. On iron heads I found a hand flat file helps a lot for keeping the walls straight. It actually cuts pretty fast...
I trust you have long shank cutters for reaching in deep to carve the bowl around the guide boss.
You can cut the (long) shank cutters a bit shorter for stability in the die grinder.
I always do the port flange opening LAST.. As we all are tempted to (over) work that area as its (Too) easy to get at.
Re: New SBC heads
Take your time. Take frequent breaks ( its not a race )
Its when you get fatigued that you tend to make mistakes. Nothing done well gets done in a hurry.
Re: New SBC heads
Funny on how that was the only port that did that but the new Splash Zone took care of that problem real quick. I like the had file deal, I may try that on the next head. I am just cleaning these up like the Iron Darts I have and then off to the bench to see how much difference there are between the ral and fake Darts.F-BIRD'88 wrote: ↑Fri Aug 26, 2022 9:00 pm I'd let it set overnight... Can't believe you carved right thru the pushrod pinch already.. At least if there is a area that is easy to repair its the pinch area in the intake port. ,(stays cool when running)The biggest skill is keeping stuff even.. On iron heads I found a hand flat file helps a lot for keeping the walls straight. It actually cuts pretty fast...
Re: New SBC heads
My nephew has set of the copies.He blew through the pinch and welded them and uses 60/40 shaft rockers on them.He filled floors and raised roof as much as possible.He has a 354 with a dom carb on e93 fuel.He runs 9.80s@3175 lb area.I saw him go 137 last nite in 3100 da.
Re: New SBC heads
Welcome, his combo sounds bad azz. Any picture of the head work you'd like to share? 9.80's is movin.Lloyd klem wrote: ↑Sun Aug 28, 2022 3:06 pm My nephew has set of the copies.He blew through the pinch and welded them and uses 60/40 shaft rockers on them.He filled floors and raised roof as much as possible.He has a 354 with a dom carb on e93 fuel.He runs 9.80s@3175 lb area.I saw him go 137 last nite in 3100 da.
Re: New SBC heads
I dont know if he took any pics of the work on them or not.I know he filled floors with epoxy and angle milled them hard.The engine is together in his car so not much to see now.
Re: New SBC heads
He is 17 yrs old.My brothers all kind of pitched in and gave him left over junk that laying around the shops.He won the heads in a raffle type deal .Its just used stuff.Sprintcar roller cam and offset lifters.Put port plates on exhaust side for better headers.
Re: New SBC heads
I really like those throw together deals especially when they run quick
Re: New SBC heads
2nd head I did today went much better using the mini-belt sander to grind the pinch open. Worked very well.
Re: New SBC heads
That sounds cool, do you have a picture of the mini belt sander in action?
Ron Miller
Re: New SBC heads
No I don't but this is one I used with a 36 grit belt from 3M.Ron Miller wrote: ↑Wed Aug 31, 2022 4:54 pmThat sounds cool, do you have a picture of the mini belt sander in action?
Re: New SBC heads
1980RS wrote: ↑Wed Aug 31, 2022 5:56 pmNo I don't but this is one I used with a 36 grit belt from 3M.Ron Miller wrote: ↑Wed Aug 31, 2022 4:54 pmThat sounds cool, do you have a picture of the mini belt sander in action?
Is that an attachment that goes on a typical electric angle grinder?
Re: New SBC heads
two smallish budget hand-held pneumatic belt sanders/files
https://www.harborfreight.com/12-in-x-1 ... 64932.html
https://www.harborfreight.com/38-in-bel ... 60627.html
