Longevity of flat plane crank engine?
Jim2527
Post by Jim2527 »
Someone brought this up over at the corvette place. What are you opinions on the longevity of a flat plane crank engine as a daily driver and if tracked?
Thanks -Jim
BCjohnny
Re: Longevity of flat plane crank engine?
Post by BCjohnny »
Assuming you’re talking about a ‘flat plane’ V8 crank …...
If the harmonics are kept in check (dampening) and the fundamental design is good I don’t see any issues over the average expected lifespan of a particular application
Why should there be ? ...... there’s more to it, but a FP crank is essentially an I4 crank and they’re hardly snapping all over the place
Ok, there’s the out of imbalance secondary, twice crank speed rolling couple that needs to be accounted for, but that’s mostly been known since the days of Lanchester, probably beyond
There’s maybe an lesser argument to be made that in light of this, in a performance application relative to a correctly engineered ‘cross plane’ crank, it could be potentially harder on bearings, and will certainly vibrate more without balancing shafts …… going up in a non-linear way relative to reciprocating weight which is why most FP engines have a modest displacement ...... but I doubt it's a deal breaker
"And if I claim to be a wise man, it surely means that I don't know"
fabr
Post by fabr »
What was/is the reasoning behind the C8 Vettes going with a flat plane crank?
Mark O'Neal
Post by Mark O'Neal »
fabr wrote: Wed Aug 03, 2022 6:57 pm What was/is the reasoning behind the C8 Vettes going with a flat plane crank?
Knowing car guys....because they sound neat?
hoodeng
Post by hoodeng »
In the seventies flat plane cranks were starting to be run in F5000 here, the most common issue was the integrity of the tubs.
I don't recall what rectification was employed but as BCjohnny pointed out, if harmonics were addressed issues could be controlled.
Exhaust tuning was the aim then.
Cheers.
Tom68
Post by Tom68 »
Better intake manifold tuning, better exhaust tuning, lighter crank.
Lot's of negatives though.
englertracing
Post by englertracing »
And to better mimic a ferrari like they were going for
BCjohnny
Post by BCjohnny »
fabr wrote:What was/is the reasoning behind the C8 Vettes going with a flat plane crank?
I'm with the other posters ........ I'd say it likely has more to do with marketing than engineering
The trade offs for a 'street' engine are hardly insignificant ....... JMO
frnkeore
Post by frnkeore »
A successful 180°, V8 engine, was designed over 80 years ago, the Novi. It ran at Indy, for 23 years, with only three engine related failures. Magneto, one broken crank and one piston. Excellent record, I would say.
It was a 181 CID engine, three main bearings, with a large centrifugal, crank driven supercharger. It started out at 450 HP and ended, with 742 HP.
Maybe 3 mains are a advantage for 180° V8 cranks?
CamKing
Post by CamKing »
frnkeore wrote: Thu Aug 04, 2022 2:31 pm A successful 180°, V8 engine, was designed over 80 years ago, the Novi. It ran at Indy, for 23 years, with only three engine related failures. Magneto, one broken crank and one piston. Excellent record, I would say.
The Cosworth, and Ilmor engines were also 180 cranks.
The Turbo AMC V8, and Turbo SBC my dad developed for Indy were also 180 cranks.
A certain IRL team made a 180 crank(and cams) for one of their N.A. GM engines. They ran it during practice, and the sound was so different, everybody at the track knew something wasn't right, so they didn't try to race it.
Schurkey
Post by Schurkey »
Because Ford did.
There was a time when GM Engineering was in a leadership position.
fabr
Post by fabr »
I agree with most that it is basically marketing. No real/substantial performance benefit.
hoffman900
Post by hoffman900 »
The flat plane crank is an advantage on the IMSA engines and how it draws on restrictors.
There are performance benefits for sure, especially when you’re chasing those last few percentage points in gains, and not just peak.
If the engineering controls are maintained and used within their design criteria there shouldn’t be an issue, just like anything else.
Tom68
Post by Tom68 »
hoffman900 wrote: Thu Aug 04, 2022 11:22 pm The flat plane crank is an advantage on the IMSA engines and how it draws on restrictors.
If the engineering limitations are maintained, i.e stroke length.
hoffman900
Tom68 wrote: Fri Aug 05, 2022 4:22 am
Right, but the aftermarket is notorious for this stuff. The OEMs spend millions of dollars to make something work and some JoeBlowHotRodder modifies it in a way that takes it outside what it was designed to do with zero consideration for the entire package and wonders why it blows up.
