msd 6 btm
- New Member
msd 6 btm
Has any body ran the msd 6 btm with out locking the timing out I am running a roots blower with about 12 pounds boost with a pro billet dist and would like to run around 20 degrees initial and 12 or 14 would give me 32 or 34 total all in by 2500 rpm but there's no way unless I run the digital e curve dist. but the main thing here is do I lock it out or not an[/img][/img]d I know I need to phase the rotor in, thanks .
Re: msd 6 btm
Running the lightest (silver) springs will advance full timing before 2500 rpm.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
