D V Live now.
Moderator: David Vizard
Tom68
D V Live now.
Post by Tom68 »
Sort of, prerecorded but he can answer in the live chat.
and no Adult Video music intro. :D
https://youtu.be/clS50nsgQeQ
HQM383
Re: D V Live now.
Post by HQM383 »
More fresh DV on lobe sep angle
https://youtu.be/IjfwqgpspnA
Tom68
Re: D V Live now.
Post by Tom68 »
HQM383 wrote: Sat Oct 29, 2022 3:06 am More fresh DV on lobe sep angle
That's a weird video, it's mostly about overlap and he keeps brining up LSA, then it's about intake closing in relation to compression and he fails to mention that and calls it LSA. Old mate obviously didn't need a low idle speed so he got away with his tight LSA, but the LSA he got was a resultant of what worked for him.
Good on him for looking after David, but this LSA obsession is a negative for all involved.
Uncle Tony (Garage) touched on overlap recently and claimed nobody talks about that.
I'm just about finished with Championship winning youtubers, they won Championships because they put their all into it, not because their way is the only way.
They're all singing different Hymns from the same prayer book. It's really disrespectful to 130 years of ice engineering.
bob460
Re: D V Live now.
Post by bob460 »
Did he ever enter EMC?
Tom68
Re: D V Live now.
Post by Tom68 »
bob460 wrote: Sat Oct 29, 2022 7:13 am Did he ever enter EMC?
You'll have to tell me what EMC is. EVC no.
bob460
Re: D V Live now.
Post by bob460 »
Tom68 wrote: Sat Oct 29, 2022 7:16 am
Sorry my bad, was just curious if he ever entered the "Engine Masters Challenge" contest.
Tom68
Re: D V Live now.
Post by Tom68 »
bob460 wrote: Sat Oct 29, 2022 7:27 am
Dunno, he brought up winning Championships (I've been involved in several Championships across several classes of racing) if you based an EMC challenge on LSA calculations you'd have to have a lot of luck on your side to pull a win.
Carnut1
Re: D V Live now.
Post by Carnut1 »
I don't think so. D.V. and Terry Walters entered the race engine challenge a few years ago. 743 hp from 420 ci Chevy with untouched Dart heads. I did the intake work for that build.
631-816-4911
9:00am - 9:00pm EST
Bigchief632
Re: D V Live now.
Post by Bigchief632 »
Carnut1 wrote: Sat Oct 29, 2022 9:14 am
I don't think so. D.V. and Terry Walters entered the race engine challenge a few years ago. 743 hp from 420 ci Chevy with untouched Dart heads. I did the intake work for that build.Resized_20190908_213029_9947.jpeg
That's the one Terry Walter's machined and built at his shop, that you did the intake on, and they used CNC'd Dart heads otb, just curious, what did David do on it? Nice job on the intake by the way.
Carnut1
Re: D V Live now.
Post by Carnut1 »
The heads were stock from Dart. D.V. did the combination, Terry built it. I had input on carb spacers and how I did the intake.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Re: D V Live now.
Post by Carnut1 »
I think the heads were as cast not cnc.
631-816-4911
9:00am - 9:00pm EST
Bigchief632
Re: D V Live now.
Carnut1 wrote: Sat Oct 29, 2022 11:08 am The heads were stock from Dart. D.V. did the combination, Terry built it. I had input on carb spacers and how I did the intake.
They were CNC.'d from Dart. You can find the info on here, the details are there.
Carnut1
Re: D V Live now.
Post by Carnut1 »
Nice. Thanks
631-816-4911
9:00am - 9:00pm EST
skinny z
Re: D V Live now.
Post by skinny z »
Carnut1 wrote: Sat Oct 29, 2022 11:08 am D.V. did the combination,
As in the cam spec as well?
Kevin
Carnut1
Re: D V Live now.
Post by Carnut1 »
skinny z wrote: Sat Oct 29, 2022 12:19 pm
Yes, he used his torquemaster program.
631-816-4911
9:00am - 9:00pm EST
