Page 2 of 2
Re: piston ring compressor
Posted: Sun Dec 04, 2022 9:02 am
by Belgian1979
gofaster wrote: ↑Sat Dec 03, 2022 12:07 pm
Talk to someone at Total Seal Piston Rings. They will make you any size ring compressor with whatever taper you need depending on the ring package. They make adjustable and solid types. They made a some for me and they are reasonably priced. You can get standard sized TS ring compressors from summit, Here's a link to an example of one of the adjustable ones:
https://www.summitracing.com/parts/TSR-RC3-780-3885
It's a similar part I've ordered. But I need a new set of rings to replace the damaged oil rings
Posted: Sun Dec 04, 2022 1:28 pm
by rebelyell
Belgian1979 wrote: ↑Sun Dec 04, 2022 9:02 am
Do tops of your bores have a chamfer aka lead-in ?
Posted: Mon Dec 05, 2022 2:15 pm
by Belgian1979
Not a lot or rather none. Hasn't been a problem with the previous rings but this time it doesn't seem to work.
Posted: Mon Dec 05, 2022 6:17 pm
by Schurkey
I don't build many engines, but I've been using that style (Lisle brand) for decades.
BEWARE the imported knockoffs of that tool. Years ago, (2004-ish) I looked at a knockoff from Taiwan.
May have been "Performance Tool" brand.
They'd punched the slots from the wrong side, the jagged, rough edge of the stamping was facing IN TOWARDS THE RINGS. I handed the tool back to the guy at the counter, told him what was wrong with it, and he calmly returned it to it's packaging and put it back on the display hook.
This is what happens when folks who don't know what they're doing, "Receive and Duplicate"; and folks who don't care, do the QA.
The genuine Lisle version works well for me.
Posted: Wed Dec 07, 2022 4:20 pm
by Belgian1979
I received the tapered compressor today. On the bottom end it has a non-tapered edge. Is that correct?
Posted: Wed Dec 07, 2022 5:40 pm
by gofaster
Yes that's right if in your application you are loading the piston from the top of the block.
Posted: Thu Dec 08, 2022 3:37 pm
by Belgian1979
A question: since it is a tapered tool, does it require you to set the bottom part equal to the cyilinder diameter and then tap the piston into it from the top, or do I clamp it around the piston with the rings like with the others.
This may be a stupid question but just to make sure.
Posted: Thu Dec 08, 2022 4:22 pm
by BillK
Belgian1979 wrote: ↑Thu Dec 08, 2022 3:37 pm
I tighten it to the point where I can just barely get the piston to slide through using the handle end of a dead blow hammer. Make sure to hold the tool down tight against the block. With that type of tool you almost don't need any bore chamfer at all. Just don't be afraid to "slam" it in. Seems like if you try to go slowly that's when the rings get caught.
Posted: Thu Dec 08, 2022 7:53 pm
by Tom68
Do it up on the piston for the first one only, do the clamp up when it's on the fat part of the barrelled skirt.
Posted: Fri Dec 09, 2022 12:05 pm
by Belgian1979
Thanks guys. I'm going to give it another go as soon as I get new rings.
