ISKY RR550 Magnum Cam
Dave at OldSchool
Post by Dave at OldSchool »
.. anyone have application & specs for an ISKY RR550 Cam it's in a 327 sbc geardrive USRRC CanAm roadracer
Re: ISKY RR550 Magnum Cam
Dave at OldSchool wrote: Mon Nov 21, 2022 8:01 pm .. anyone have application & specs for an ISKY RR550 Cam it's in a 327 sbc geardrive USRRC CanAm roadracer
Dave, back in the day, the catalog said:
Iskenderian RR550 - Timing supplied with cam
FWIW, that was the mid-level roller; there was an RR7000.
6.50camaro
Post by 6.50camaro »
Don't know if this helps but, from a 1970 Isky catalog they list a 550 grind number as having .540 lift valve timing In 57-93 Ex 93-57 330 degree duration .030 lash. those timing numbers give it a 108 LSA . they define type as Super LeGerra in the back of the catalog they list this as 1/4 mile drag, smooth action allowing over 8000 rpm, supercharged or N/A. Dan
BillK
Post by BillK »
Why dont you call them and ask. I would bet you dinner that they will know the answer.
(310) 217-9232
smclendon
Post by smclendon »
I ran one in 1967 in a 1955 Chevrolet C/MP with a 327. Over a Crane 308 roller it was about 2mph. faster. I am sure Isky can give you the information.
Geoff2
Post by Geoff2 »
There were a lot of 'RR' category cams. The numbers usually referred to the valve lift.
