What engine combo is that on? did you test spacers to arrive at that as the best combo for your setup? I have an rpm air gap and had a 1" hvh tapered on it, reason I am asking as I'd love to know more. Thanks.
- New Member
I haven't made it that far yet, bud. Been stalled forever on a block but it's a 10.4 ish 406 SBC for my '83 K10. I knew we'd have to test so I started with the tallest one because it looks cool, lolRickSBC400 wrote: ↑Sun Feb 19, 2023 5:48 pmWhat engine combo is that on? did you test spacers to arrive at that as the best combo for your setup? I have an rpm air gap and had a 1" hvh tapered on it, reason I am asking as I'd love to know more. Thanks.
Or a high compression 406 with VFactor heads?SpeierRacingHeads wrote: ↑Wed Feb 15, 2023 11:04 am The only thing I'm curious about is does all this apply on every engine? I say nope.
Would the results be the same on a 406 or 434?
Inspired by Chad...
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
- New Member
I look forward to hearing about it.RevTheory wrote: ↑Sun Feb 19, 2023 6:08 pmI haven't made it that far yet, bud. Been stalled forever on a block but it's a 10.4 ish 406 SBC for my '83 K10. I knew we'd have to test so I started with the tallest one because it looks cool, lolRickSBC400 wrote: ↑Sun Feb 19, 2023 5:48 pmWhat engine combo is that on? did you test spacers to arrive at that as the best combo for your setup? I have an rpm air gap and had a 1" hvh tapered on it, reason I am asking as I'd love to know more. Thanks.
More plenum work on the Holley 300-25 Strip Dominator...
Always knew we were copping BS off JM in all the old printed literature.1980RS wrote: ↑Tue Feb 14, 2023 9:42 pmHey now, McFarlain said the tork-link was the best intake since canned beer
https://youtu.be/JW21G0o1bdk Go to 55.27 for the bulk of the flaming.
Excellent He was supposed to work on the springs... 33:19
-juhana
-juhana
AFR 4811 revisited…
FWIW,the burr finish will go the way of the dinosaur within the next few years.Just my uneducated .02mt-engines wrote: ↑Wed Feb 08, 2023 5:00 pmNo way that works..
No aggressive burr finish.
I'm surprised it even idles.
Diving deeper into the Weiand Team G 7531. Work in progress...
Scott,ChopperScott wrote: ↑Thu Mar 02, 2023 6:55 pm Diving deeper into the Weiand Team G 7531. Work in progress...
Is that by hand or mill?
Those taller plenum Team G have a ton of material.
I am looking at getting a mill so I can machine the plenum area's, save a lot of grinding
Steve,
That is by hand. I don't have a mill.
A ton of material and a ton of work.
The carb pad is still a 4150.
I've got a 'few' more hours grinding into it since those pics.
