steve cowan
Post by steve cowan »
SpeierRacingHeads wrote: Mon Mar 20, 2023 4:48 pm Super Stock racer Timothy Stickles and his SS/KA Malibu picked up (his words) a conservative .15 over his Heads Up Victor E manifold.
327/300hp w/QJet.
Finished in B U R R...
Chad,
Is the spacer/adapter welded on the inside?
I can't see a parting line.
The victor E is a awesome manifold, if they cast them today they would sell like hotcakes
SpeierRacingHeads
Post by SpeierRacingHeads »
steve cowan wrote: Tue Mar 21, 2023 5:15 am
327/300hp w/QJet.
Chad,
no, just blended.
Speier Racing Heads
Chad Speier
785-623-0963
EDC
Post by EDC »
Throwing a curve at you Scotty... Small block Ford...
The AFR intake. No more cloverleaf. Almost done. Still have to do a bit more to match the heads.
Nil Satis Nisi Optimum
ChopperScott
Post by ChopperScott »
Very nice work, Ed. I wouldn’t mind getting my hands on a blue oval intake. In the meantime, this Strip Dominator is ready for competition…
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
skinny z
Post by skinny z »
I'll ask if any of you all are watching Weingartner's intake manifold testing but I'm pretty sure you are.
The link below is round two.
https://www.youtube.com/watch?v=NU9lnYZXlGo
It slots into this thread very well.
Very well except the lack of dual planes here (but that's just me and maybe 1980RS). Eric is slated to test of couple of dual WITH a 1" open spacer. Finally!
Anyway. I'd be interested in the feedback to those vids and how it shakes out with testing done by my SpeedTalk brothers (and sisters).
Kevin
Tom68
Post by Tom68 »
Needs its own thread on here, Youtube is crap as a comments forum.
skinny z
Post by skinny z »
Tom68 wrote: Mon Mar 27, 2023 8:58 pm Needs its own thread on here, Youtube is crap as a comments forum.
I can agree on the comments part of it. More or less useless other than a money generator I suppose.
But are his videos insightful? Accurate? Seems to me they are presenting facts and results rather than speculation.
I certainly won't be one to test in that extreme. Best I can see (for me) is a spacer or two in back to back track runs. But the days of pulling off a manifold swap at the track are long gone.
Kevin
ChopperScott
Eric plugged Speed Talk in that video, but wasn't thrilled. I'm sure a dedicated thread would garner more attention. Otherwise, it gets buried under my garbage...
Tom68
Post by Tom68 »
skinny z wrote: Mon Mar 27, 2023 8:46 pm I'll ask if any of you all are watching Weingartner's intake manifold testing but I'm pretty sure you are.
I don't think Eric has needed to have a good hard think about what happens in Dual Planes, he might get a surprise how much difference lowering that divider makes on the Performer even though he did run it with a 1" open spacer last time.
Pity he didn't run a divided spacer when it had the full divider in tact.
ChopperScott
Two different approaches to the same manifold. One is ported to work with AFR Eliminator heads 195cc or larger with a 6901 gasket. The other is matched to a 1206.
Bigchief632
Post by Bigchief632 »
ChopperScott wrote: Wed Mar 29, 2023 3:54 pm Two different approaches to the same manifold. One is ported to work with AFR Eliminator heads 195cc or larger with a 6901 gasket. The other is matched to a 1206.
How much bigger is the exit of the manifold than the inlet of the heads?
ChopperScott
Bigchief632 wrote: Wed Mar 29, 2023 4:58 pm How much bigger is the exit of the manifold than the inlet of the heads?
I'm using a mock-up block with AFR 220 Comp heads and CNC ports. A 6901 gasket is 1.36"x2.26" vs the 1206 at 1.31"x2.21".
AFR 220 Comp head...
AFR manifold with CNC ports...
AFR manifold ported by me with burr finish...
289nate
Post by 289nate »
EDC wrote: Wed Mar 22, 2023 7:21 am Throwing a curve at you Scotty... Small block Ford...
This is what Toby and I have discussed doing for my build. The intake is also slightly wider to help with port alignment.
SoCalDave
Post by SoCalDave »
I've watched some videos on Youtube for intake manifold porting so I've got an idea as to the mods to make on the Torker ll. Progress so far..
ChopperScott
SoCalDave wrote: Sat Apr 01, 2023 1:14 pm I've watched some videos on Youtube for intake manifold porting so I've got an idea as to the mods to make on the Torker ll. Progress so far..
Coming along nicely. Take your time. What type of bits are you using to port?
