Composite Quarter Elliptic Springs
agertz1
Post by agertz1 »
Is currently semi, still easy to rate test first 1/2" of compression. Divide by 2 for new rate ? Inverted to create more " roll caster gain" as upper link to
straight axle. May use a curved upper clamp on fixed end,( rising rate). Near clamp points, attach anti roll bar, as need.
Thoughts ? Thanks, Art.
In-Tech
Re: Composite Quarter Elliptic Springs
Post by In-Tech »
Hiya,
It appears to me you are way ahead of the curve, just curious if the spring and holder(s) is in a near or no friction environment so it doesn't change during environment with large sway high movement.
Of course not completely attainable even with needles, just seems more attainable than with bushings. Just curious. My mind might be in a different space than yours :lol:
An elliptic spring is very interesting, especially in environments where opposite winding interference could help with damping. The only elliptic testing I have ever done was hollow stem, I've never heard of hollow stem winding extruded to wire. Sounds cool =D>
-Carl
Tom68
Post by Tom68 »
agertz1 wrote: Thu Feb 02, 2023 6:50 pm Is currently semi, still easy to rate test first 1/2" of compression. Divide by 2 for new rate ? Inverted to create more " roll caster gain" as upper link to
What's the application ?
Going to 1/4 elliptic then of course needing to add an antiroll bar. :?
Rick!
Post by Rick! »
Roll caster gain on a solid axle with an upside down leaf spring as the upper connection ala AC Ace?
Maybe with the lower link attached in front of the axle instead of the typical aft axle position on 4WD pickups.
Draw some simple diagrams and figure out how you can add compliance to the leaf spring connection at the king pin so you don't try to make it twist during operation.
Caster gain is easy to achieve in an SLA suspension, not so much in a solid axle.
agertz1
Post by agertz1 »
V16 street roadster, about 1,600 lbs. Front springs and lower radius rods in urethane or heims. Yes, limited amount of roll caster gain,
( bushing compliance). Fixed end of inverted spring mounted on top of frame/engine girdle. Curved upper clamp to provide rising rate.
roverman
Post by roverman »
Anti-roll bar only if needed. Between low CG and rising-rate spring, might be enough. Inner pivot of leaf is horizontal sperical bearing.
How much spring travel and what will be limiting it?
Back in the bad old days, my guru told me, "Any suspension design can be made to work if you don't let it."
