Who says you can't open a valve by pushing on the retainer
Blow up rebuild so there' a bit of juggling going on with valve heights.
Springs supplied based on a phone call to the supplier were a bit heavy for the purpose.
Valves supplied from the same manufacturer gave different heights from the tip to the retainer for the exh and intakes.
Plus 50 locks are smaller OD than standard locks......so more than plus 50
Being a slack ass didn't check everything as thoroughly as a younger me would have.
Engine does a day on the Lake to break it in, 5500 max rpm.
Put rev limiter MSD module in, hold revs at 3250 to set redline at 6500, smash the throttle several times, 6500 limit confirmed.
Get a feeling I should pull the rocker covers and make sure everything looks good.
Result, I have inlet rockers contacting retainers, on the damaged cylinder.....I can spin the roller, it's off the valve stem when closed.
Put standard height locks on intakes only, don't want to add any more seat pressure than I have to, springs still above 1.8" installed height.
Picture is Exhaust valve as it will run going forward and how it was running.
Re: Who says you can't open a valve by pushing on the retainer
When you don’t apply what you darn well know you should do in terms of assembly check outs do you really expect Murphy’s law to not bite your Ass?
I think your lucky you got the two or three rev up session that you did out of it without busting a push rod and having a lifter head for the sky out of its bore!
Dumb ass amateur build from a guy who criticised me for relieving rockers to avoid this very situation .... you couldn't make this up
Yeah sorry, shot from the hip there, bit too frank ...... I'd delete it if I could ....... not my usual courteousness
I have clearanced a set of stainless steel rockers before. Didn’t know it was controversial.
- Dave Koehler
It's not. One does what one must do.
That is normal for Ford Crane used to sell the locks in a kit with half of each.
I have never experienced that ? Who's locks are you using ?
I can tell you this... All parts seem to be lower quality than in previous years. Seems like when the push to produce outweighs the desire to ship out quality there is always trouble.
Better check EVERYTHING....
You always had to.
A friend in the 1960s would have to buy 5-8 aftermarket camshafts and measure every lobe to get one where they were all close. These are reputable names from American outfits. He was a championship winning engine builder.
Engine, chassis stuff, you have to check everything.
It was a juggle, I don't want the roller tip any further outboard from the valve centerline, longer pushrods was also an option, but both options push the rocker further up the stud and move the roller tip out.
Comp I think, they may have been correctly sized, but the standard height ones that they were replacing were slightly larger O.D.
These would have clearanced OK, it's a budget build, and whilst blowing it up isn't an option neither's going backwards financially, I wouldn't touch them with a grinder or a cutter without pulling the needle rollers out, add that to the clearancing and time's adding up.
Better spring choice with a lower installed height was the answer, deadlines didn't allow for a change, note to self, do you're own research rather than taking advice from a supplier, I did send a sketch of my installed dimensions etc, I just wasn't willing to run the pressures they said would be OK.
Yer and I was taking shortcuts with ordering because I was late getting the parts organised.
Without looking back at my answer to your clearancing post, from memory your rockers were getting thin in that critical tensile area, hopefully I was only reinforcing care in a critical area.
If I was being an arse, your response to my f'up was justified, and of course my poor checking on my rebuild was piss poor anyways, so still justified, got lucky but. Doh...so far that is.
That's the intake contact, Can't remember which Rocker manufacturer mentioned once you rotate the rocker to get pushrod pinch clearance you no longer have square contact through the full range of travel. Shows up here with wider contact on one side. Bring on the cheap shaft rockers with offset pushrod cups. I've mostly worked with factory rockers and shaft rockers, these stud mount rollers are a can of crappy worms.
