Mission Impossible 318ci 318HP
juuhanaa
Re: Mission Impossible 318ci 318HP
Post by juuhanaa »
That doggone divider has already been cut down, but how can we know or get a hint if the robbing action is excessive?
-juhana
patrickonb
Post by patrickonb »
I just don't get it! Going through all of this work, but won't opt for at least a factory 4 barrel manifold and carb? SMH. It's just painful! :cry:
Tuner
Post by Tuner »
juuhanaa wrote: Mon Feb 20, 2023 3:13 am That doggone divider has already been cut down, but how can we know or get a hint if the robbing action is excessive?
-juhana
That stock intake has a common plenum, the bores below the carb flange are only about 1/2" long below the gasket surface.
Tuner
Post by Tuner »
patrickonb wrote: Mon Feb 20, 2023 8:26 am I just don't get it! Going through all of this work, but won't opt for at least a factory 4 barrel manifold and carb? SMH. It's just painful! :cry:
Why ask why? Just because they can. Keep your Debbie Downer schlepping in your own lane. Most would cheer for a stock class racer who has to use that intake and carb and gets national record setting power from it.
Stan Weiss
Post by Stan Weiss »
JMO
Charlie is seeing lets say 205 - 210 cfm without the carb @ 28" water. I believe the carb DV modified is flowing well above that @ 28" water. So the engine seeing 5.5- 6" Hg @ WOT peak HP RPM will have enough flow for 318 ci 318 HP. Remember 2 barrels are rate @ 3" Hg from the factory.
patrickonb
Tuner wrote: Mon Feb 20, 2023 8:54 am
Wow! Take some downers and relax pal, I'll ask why all I f'ing feel like!! Welcome to America, where we have freedom to ask questions!
Tuner
Post by Tuner »
patrickonb wrote: Mon Feb 20, 2023 10:04 am
You didn't "ask why", you criticized them negatively for not doing it your way. You can take all the downers you want. If you didn't take so many you might not have such a negative attitude about somebody else's project.
juuhanaa
Post by juuhanaa »
All in all, a good project that seems to make people think and do stupid things for a good cause
:lol: I just google Debbie Downer. I like it, kinda hot.
-juhana
patrickonb
Tuner wrote: Mon Feb 20, 2023 10:14 am
I simply stated I didn't understand why they wouldn't use a 4 barrel setup, that's not criticizing anything, but hey, if it floats your boat, enjoy!
Stan Weiss
What challenge is there in trying to made 1 HP per ci with a 4 barrel carb? The OEM auto manufactures did that over 60 years ago.
patrickonb
Stan Weiss wrote: Mon Feb 20, 2023 10:22 am
I guess there is no challenge.
I guess I totally misunderstood what David Vizard was trying to accomplish with this setup. But who cares, it's got nothing to do with me.
Carry on, enjoy.
mt-engines
Post by mt-engines »
Just throw it on Terry Walter's dyno. Should make 450hp easy.
patrickonb
I apologize for hurting anyone's feelings, that was not my intentions.
I apologize for the afterward attitude.
I will keep my opinions to myself from now on.
I'm sorry.
Patrick
Elroy
Post by Elroy »
mt-engines wrote: Mon Feb 20, 2023 10:41 am Just throw it on Terry Walter's dyno. Should make 450hp easy.
Its already been on a flowbench, isn't that the same as a dyno? :D
juuhanaa
Post by juuhanaa »
Elroy wrote: Mon Feb 20, 2023 11:05 am
Not really, because on a dyno we can atleast let it idle. :mrgreen: \:D/
-juhana
