The Torque Horsepower thread.
Open to topics unrelated to Speed-Talk.
No politics. No religion topics.
Tom68
Post by Tom68 »
Torque comes first because it's part of the equation to display the outcome, Horsepower.
Horsepower wins races, well not really, Handling (traction aero driving etc) wins races when there's enough Horsepower to back it up.
Torque is easy, just bolt ten gearboxes in a row behind your 2 litre, stick them all in 1st and you'll have the most torque on the block.
ENJOY :lol:
juuhanaa
Re: The Torque Horsepower thread.
Post by juuhanaa »
Not all races. The MIG-21 was speed limited due to directional stability, so in that case there was not enough aero to support the horsepower.
The evolution of gasoline-powered World Rally Cars ended in 2021, after the 1.6 liter Toyota Yaris won the world championship.
-juhana
gunt
Post by gunt »
READ A TING , LONG TIME AGO ,
605lb tq couldn't brake 200mph , but the same engine reconfigured , just took 450bhp to brake it , so there is a point where its needed regardless , also look at the 1/4 mile times , and the sort of things that simply should not be happening , fwd's and other odd tings
arlancam509
Post by arlancam509 »
horsepower isn't real. it is the result of a calculation.
you can't hold it in your hand.
° alt+0176 °
panic
Post by panic »
Time isn't real, you can't hold it your hand.
juuhanaa
Post by juuhanaa »
I have been told to avoid slow horses and fast women.
-juhana
juuhanaa
Post by juuhanaa »
https://www.youtube.com/watch?v=Zotv22Zz-AY
Neuville has it and the builder of this transmission deserves a metal.
-juhana
1980RS
Post by 1980RS »
Torque gets the car going, Horsepower keeps it going to the end of the track. The more you make of both the quicker and faster you'll go.
Bigchief632
Post by Bigchief632 »
1980RS wrote: Sat Feb 25, 2023 8:33 pm Torque gets the car going, Horsepower keeps it going to the end of the track. The more you make of both the quicker and faster you'll go.
In the rpm range you run in. It's all relative.
1980RS
Post by 1980RS »
Bigchief632 wrote: Tue Feb 28, 2023 10:10 am
I never let my relatives touch anything I own :lol:
