Comp Cams Custom Small Block Chevy Solid Roller Camshaft
I have a Comp Cams Small Block Chevy Solid Roller camshaft, custom ground for TurboCharger, but would work great with Supercharger as well. The camshaft has dyno time only, it is the same as new. This camshaft has the 1.948" Big Block Chevy bearing journals and is 4/7 Swap Firing Order. Check out the photos for camshaft specs. It also has a step-nose so that it is compatible with all standard Small Block timing components. Camshaft will ship in a Cam Motion camshaft box. We bought this to use in an engine we are building, but we ended up changing the combination quite a bit, so we decided to order another custom camshaft instead. $350 Shipped to your door step in the lower 48. Price includes Paypal fees as well.
