tires info
prairiehotrodder
tires info
Post by prairiehotrodder »
has anyone tried stiff sidewall slicks back to back with regular sidewall on a car with lots of power ? Something maybe in the 9's or faster ? Does the stiff wall tires just spin easier because it doesn't cushion the hit ?
Brian
SupStk
Re: tires info
Post by SupStk »
Since no one responded, thought I'd throw this out.
A customer runs a 9.90 roadster with a 900 hp BBC. He went to stiff sidewall slicks (don't recall the number) from 1984 Goodyears. Slowed the car down about a tenth but improved reaction times, which was what he was aiming for.
Monty Frerichs
B&M Machine
prairiehotrodder
Re: tires info
it slowed the car down because his 60 foot got worse ? Thanks for the reply, I'm trying to improve my 60 foot so based on your info sounds like i should avoid the stiff sidewall tires.
Brian
SupStk
Re: tires info
Post by SupStk »
prairiehotrodder wrote: Fri Mar 10, 2023 10:52 am it slowed the car down because his 60 foot got worse ? Thanks for the reply, I'm trying to improve my 60 foot so based on your info sounds like i should avoid the stiff sidewall tires.
Brian
Not sure where the loss occured. Pretty sure it didn't loop the tires off the line. The Goodyear 1984s grow some on the top end.
Monty Frerichs
B&M Machine
bobmc
Re: tires info
Post by bobmc »
what does leaving at a higher RPM do to your 60' time?
gordon
Re: tires info
Post by gordon »
The stiffer sidewall tires are normally quite a bit heavier. Affects static weight and rotational mass during acceleration. This could cause a change in ET
