ET_Analyst for DragRacers Pro version 1.00
Download Link : click the ETAPRO1.zip Link below
Download Instructions :
download the ETAPRO1.zip file to your Window's "Download" Folder
or to a Folder of your Choice ( Caution: never download to a Temp Folder )
then Right-Click on the ETAPRO1.zip file
to Extract or UnZip ETAPRO1.zip file
double-click on the ETAPRO1.exe file to Run the software
ET_Analyst_for_DragRacers_Pro1 ( only for Windows PC Operating Systems )
a very affordable Software for only $49.00 USD
Turn your RaceCar into an Engine Dyno ... everytime you make a DragStrip Run
by turning your RaceCar's ET Slip Run Data back into Engine Dyno Flywheel HorsePower
Discover at what DragStrip Feet distance(s) you are making Peak HorsePower at ,
and the amount of Peak HP ... now you can find out with ET_Analyst_for_DragRacers_Pro1
ET_Analyst_for_DragRacers_Pro1 Features :
1]= ET_Analyst Software never needs to be installed ( totally eliminates all installation problems )
ET_Analyst Software is a single Portable Stand-Alone .EXE Application ( no other support Files are necessary )
ET_Analyst Software is a very small size .EXE that is highly optimized and has extremely fast Data results !
ET_Analyst Software is a Windows PC 32-Bit Application that runs on both 32-Bit and 64-Bit Windows PC
ET_Analyst Software is designed/programmed to run on Windows Vista upwards to lastest Windows 11 versions
ET_Analyst Software 32-Bit version will also Run on Windows XP Operating System in all my Tests so far
a 64-Bit ET_Analyst version is avaliable on request, however, in all my testing,
the 32-Bit version has been highly optimized so much, i cannot tell any speed differences between 32 or 64-Bit versions
2]= Calculate and Simulate a 5 HP Jr Dragster all the way to a 11,000+ HP Top Fuel Dragster with very high accuracy for
each and every Feet distance down the DragStrip ! ( even past 1320Ft, all the way to 1600Ft )
ET_Analyst_for_DragRacers can accurately simulate a Top Fuel Dragster's Clutch progressively locking up on a Run
3]= Calculated Data results 9 Columns are :
Column 1= Feet distance ( in 1 Foot distance increments )( DragStrip Lengths : 660Ft, 1000Ft, 1320Ft, optional 1600Ft )
Column 2= ET or Elapsed Time in Seconds
Column 3= real MPH ( and ET Slip MPH 1st Page )
Column 4= Tire Contact Patch HorsePower
Column 5= Engine Dyno Flywheel HorsePower
Column 6= Ram-Air HoodScoop HorsePower gains
Column 7= Aerodynamic HorsePower Losses
Column 8= all Front and Rear Tire HorsePower Losses
Column 9= Rear Weight Transfer PerCent %
4]= Includes a Professional very accurate complete Weather Calculator ... with many extra Features ,
such as , includes 43 of the most popular Weather HorsePower Correction Factors / Equations
5]= Includes many example Simulation Files you can study, and for help in properly using ET_Analyst_for_DragRacers software
Each Choice and InputBox in ET_Analyst software has built-in Help text , and many also have helpful Pictures to look at
There are a lot more ET_Analyst_for_DragRacers Features, too many to List , here are many helpful Pictures below :
Re: ET_Analyst for DragRacers Pro version 1.00
ETAPRO1's 31_included Simulation Files :
the Professional Weather Calculator
the 5 Aerodynamic Calculators
the 8 RPM-MPH-Tire Calculators
all these 14 Calculators work 100%
yours for FREE just for testing/trying out ET_Analyst software
Please Post or Email me :
"the Good, the Bad, the Ugly" thoughts you have about the ET_Analyst software
... this is version 1.00 , so Comments, Ideas, Feature Requests are very welcomed
for the next version 2.00 of ET_Analyst software
Larger ScreenShots are available here at this Link :
https://www.maxracesoftwares.com/forum/ ... f=19&t=280
I use the oldest version. To dial in my car once I got the variables to match with my logbook on a few runs now all I do is put in current weather and altitude very accurate.
ET_Analyst for DragRacers new version 2.00 is now available ( Updated April 7 2023 )
new version 2.00 changes :
ETAPRO2.zip Download Link :
https://www.maxracesoftwares.com/forum/ ... php?id=112
or Direct Link :
New changes in ET_Analyst for DragRacers version 2.00 are :
increased the Wet Bulb choice equation accuracy ,
to be same Level accuracy as the other 4 Choices :
Relative Humidity % , Dew Point Vapor Pressure, Dew Point Temperature , and Water Grains inputs
New Wet Bulb accuracy is now 0.000 HP difference to a maximum of 0.01 HP out of 2000+ HP Engines
Old Wet Bulb accuracy was 0.000 HP difference to a maximum of 0.50 HP out of 2000+ HP Engines
new Wet Bulb equation now "mirrors" Smithsonian Meteorological Tables published for Dry Bulb / Wet Bulb
calculations from -60.0 DegF -to- 198.0 DegF
also ETAPRO's Weather calculations "mirror" Smithsonian Meteorological Tables for Dry Bulb Saturation Pressures
from -65.0 DegF -to- 212.0 DegF
ETA Pro's Weather calculator also "mirrors" the 1976 International Standard Atmosphere Tables
as to Geopotential and Geometric Pressure Altitudes from -16500 Feet -to- 36100 Feet
( Note : in the the 1976 International Standard Atmosphere Tables the Values are "Trimmed" instead of Rounded-off )
in ETAPRO the values are not trimmed, instead they are rounded-off to nearest 6 decimal places
which overall is a little better accuracy than the 1976 International Standard Atmosphere Tables
Purchase + Register ETAPRO2 to receive your UnLock Code
to fully activate the ETAPRO2 version
You can also choose not to Purchase or Activate ETAPRO Software
in that case , ETAPRO's 12 included MotorSports Calculators are fully functional
without you purchasing or activating ETAPRO software ,
all 12 Calculators are yours completely "FREE" to use just for trying out ETAPRO !
12 "FREE" Calculators List :
1]= Weather calculator ... professional highly accurate Weather equations and Data results !
2]= Aerodynamic Drag Coefficient Calculator
3]= Aerodynamic Lift Coefficient Calculator
4]= Aerodynamic Vehicle Frontal Area Calculator
5]= Engine RPM Calculator
6]= Vehicle MPH Calculator
7]= Differential or Rear Gear Ratio Calculator
8]= Torque Converter / Clutch / CVT Lockup PerCent Calculator
9]= Tire Growth Calculator
10]= Tire Size Calculator ... ( Tire Rollout, Diameter, and Radius results )
11]= Tire Metric -to English Units Converter calulator
12]= JackShaft Final Drive Gear Ratio Calculator
Download Link :
MaxRaceSoftware Home Page :
or Direct Link :
Download Link :
What's new in latest ET_Analyst Pro versions and upgrades :
New changes in ET_Analyst for DragRacers version 3.00 are :
( all Data displayed in 100 RPM increments )
1]= display's Peak Torque and Peak HP in separate Heading
2]= calculates full Torque and HorsePower Data
3]= calculates the Volumetric Efficiency % PerCent of the entire Induction System
4]= calculates the entire Induction System Flow CFM @ 28.0 inches FlowBench Test Pressure
5]= calculates the Intake CFM Demand @ 28.0 inches FlowBench Test Pressure
6]= calculates the maximum or peak Piston CFM Demand
7]= calculates the Piston Speed in Feet per Minute
larger ScreenShots here :
ETAPRO 3.0 download Link here :
