Longer-term Storage Than Planned
I'm looking for suggestions on what I might do to provide optimum long-term cylinder wall protection on my long block. Due to part availability issues, errors on parts found during upper-end assembly and changes in valve train geometry, this engine has taken quite a bit longer than planned. The usual short block assembly and lubrication was followed, all orifices are plugged and the engine has been bagged. But with these delays and the high humidity environment I live in, I'm a little worried. I ran a bore scope into each of the cylinders through the spark plug holes. Generally everything looks good although I do see a couple of very small discolored areas or stains in one cylinder wall.
I'm probably 3-4 weeks from starting the engine. Is there a dessicant I might consider in the mean time? Is there a lubricant other than engine oil that would provide better protection to cylinder walls? Or, should l just leave it as-is and continue once per week engine rotation with a break bar?
Thanks Much.
Thanks Much.
Re: Longer-term Storage Than Planned
Use ATF. Engine oil will dry out, ATF will not. With grease, it is easy to miss a spot. With a liquid, it will cover everything.
Thanks much Geoff. I did an initial cylinder wipe with ATF for cleaning purposes before oiling the rings / piston install but will go back and apply now for added protection.
This accomplishes nothing, can only scrape/displace any lube, worsening it, sucks in humidity & expels lube vapor, and the spring compress don't care.
Don't touch it, daily, weekly, monthly, whatever.
It's the fast temp change, cold to warm & its condensation that really hurts stuff.
How long has it actually been since you assembled it ? A month ? A year ?
Fog it, put the plugs in and back off the rockers. Seal it in a bag on the stand with a Damp-Rid bucket or sim.
Assembled 3 months ago. I'm hopeful to button it up in 2 weeks.
I also thought about the fogging oil spray. I wish there was a method of getting good cylinder coverage with the heads on.
there is a product or tool in the aviation world that does just that.Polysphere wrote: ↑Sun Mar 19, 2023 8:30 am Assembled 3 months ago. I'm hopeful to button it up in 2 weeks.
Thats nothing. I thought you were talking years. Squirt a little oil in each cylinder and fire it up. I bet half the engines I have built for guys doing restorations dont get started for a year or more.Polysphere wrote: ↑Sun Mar 19, 2023 8:30 am Assembled 3 months ago. I'm hopeful to button it up in 2 weeks.
I used desiccant spark plugs and my engine sat for 4 years. Backed the rockers off, didn't rotate it. Cylinders still looked perfect with a borescope..
My 421 is in my house, the kitchen doubles as an assembly area, like hell was I leaving that to rust in the garage in humid Virginia. Ahhh, the advantages of being single lol
Phillips 66 makes an R & O oil specifically to combat rust and oxidation.
Other oil companies may have similar products.
Stapleton42 with Lake Speed and Greg Anderson. (Spoiler alert, it makes the same power.)
This C3 Ford was a FRESH REBUILD back in 2004 and left unused inside former NASCAR driver Lake Speed's race shop. It has some seriously ugly surface rust INSIDE the cylinders from two decades of humid North Carolina summers, and we throw it on the dyno at PME! Lets compare how much power it made in 2004 vs today, THEN tear it down and inspect it with high tech equipment! You will see this engine evolve with a rebuild using modern pistons without changing the valve train to see how much better modern engine tech really is
https://www.youtube.com/watch?v=tttgTCnZsN4
