New aluminum heads and extended RPM range
blackford
Re: New aluminum heads and extended RPM range
Post by blackford »
Joe-71 wrote: Tue Mar 21, 2023 12:44 pm I hate to be the "naysayer" but, what is the average gain in airflow with your camshaft lift? That will be more in line with how much horsepower you can expect to gain. It has been my experience that if you don't change the camshaft, you will only gain 1 hp per cfm of airflow increase. I have yet to see the dyno results for the so called 2hp/cfm increase unless you have over 13:1 compression, and tunnel ram intake. JMO, but to see triple digit increase will not happen unless you change more than the heads. Joe-71
I know it's surprising. The old heads probably flowed 220 cfm or so. The new heads are 60 cfm better. I'm wondering though what the old heads really flowed at 7000 rpm where they were most likely choking. Here is the EA Pro printout showing the HP increase in red
65 Mustang FB, 331 custom built with 289 H beam rods and 383W piston, 282S cam, Ported Maxx 180s, T5z, 9" 3.89 gears. ~460HP@6500
2013 Corvette 427 Convertible daily driver
BobbyB
Post by BobbyB »
blackford wrote: Tue Mar 21, 2023 1:46 pm
Wow! big increases up top. I am surprised it shows small losses below 4500 rpm... are you surprised to see the losses?
blackford
Post by blackford »
BobbyB wrote: Tue Mar 21, 2023 1:57 pm
I figured it was because the smaller ports of the old heads promoted more torque at the lower rpms.
Tom68
Post by Tom68 »
blackford wrote: Tue Mar 21, 2023 3:21 pm
Or stifled torque through most of the rev range.
BobbyB
Post by BobbyB »
Tom68 wrote: Tue Mar 21, 2023 4:08 pm
What do you mean, Tom? Do you not think His simulation numbers are accurate?
Tom68
Post by Tom68 »
Nah good but there's more ups than downs with the better flow.
