piston clearance/ rock at tdc
Matt Compton
Post by Matt Compton »
Can somebody school me on what is acceptable piston to head clearance with directional change rock at tdc? Particularly 4.630 bore and 4.125. I feel like I should know this but I'm coming up short. Thanks.
panic
Re: piston clearance/ rock at tdc
Post by panic »
Skirt length, rod ratio, pin offset are all factors.
Matt Compton
IF a moderator would like to delete this post I found a thread that has answered my questions
panic wrote: Tue Mar 21, 2023 2:30 pm Skirt length, rod ratio, pin offset are all factors.
And piston-to-wall clearance as a function of diameter. The same P/W clearance will produce more rock in a 4.630" bore than in a 4.125".
