395 stroker small block chevy
Gregory
Re: 395 stroker small block chevy
Post by Gregory »
This should be of interest to those on this thread: When the 408” FI engine now in my C4 corvette was on the dyno it was 600/615 HP @ 6.6/6.7 RPM.
TriY headers gave up a little on the top end but, really picked the torque up around 4K (thank you Calvin Elston). What was a pleasant surprise was
how accurate Engine Analyzer Pro and Dynomation simulation software was - they were within roughly one percent of each other on the HP and at what RPM but, a “little” high on the torque. Good data in good data out.
If you want to play with engines, these simulation softwares are dollars well spent.
Greg Finnican
Charlotte, NC
1127thunder
Post by 1127thunder »
Itsfor my street stock dirt
steve cowan
Post by steve cowan »
1127thunder wrote: Fri Mar 24, 2023 1:31 pm Itsfor my street stock dirt
What fuel are you using?
I would think also more duration with that compression.
I suspect a 1.7 rocker with that intake lobe to get 680" lift.
I think it would run pretty good for a dirt car especially out of the corners.
1127thunder
I run av100 ll gaz the cam has 645 in and 630 and on the card must use 1.6 ratio 298 309 240 252 at 50. 108 cl
af2
Post by af2 »
Bigchief632 wrote: Fri Mar 24, 2023 9:51 am
1127thunder wrote: Thu Mar 23, 2023 5:12 pm 4.030 bore 3875 stroke 6.00 rods zero deck 027 cometic gasket 62 cc heads 2.100 valve delwest titanium 1,6 ex carb aed 1000 cfm my head flow 322 at 700 and 250 exhaust or i will put my other cam 294 308 260 in 272 at 50 669 lift intake 630 ex with 1.5 rockers lash 12 in 20 ex i think with this cam mo hp but i will loose torque
What's the application? You might want to run a thicker head gasket. I don't know why you guys run that so tight, there's no advantage other than the small gain in compression, with the risk of the piston smashing the head.
Because he wants to shift at 6000 and will never see when things actually grow.......
GURU is only a name.
Bigchief632
Post by Bigchief632 »
That cam might make traction tough on dirt.
Bigchief632
af2 wrote: Fri Mar 24, 2023 6:38 pm
It is a circle track dirt application, it'l see plenty of heat. I still say there's no advantage to running it that tight unless it's to gain compression.
1127thunder
Dyno run result 641hp at 6800 and 541 ft torque not bad
novafornow
Post by novafornow »
Was this with the small or the bigger cam?
1127thunder
Big cam
Bill Chase
Post by Bill Chase »
Gregory wrote: Fri Mar 24, 2023 12:07 pm This should be of interest to those on this thread: When the 408” FI engine now in my C4 corvette was on the dyno it was 600/615 HP @ 6.6/6.7 RPM.
Greg Finnican
Charlotte, NC
Curious, what they cost you, if he made a jig. I'd love to get a set of tri-y made for my c4. Got any photos, or other data of the build.
1127thunder
I think my street stock dirt will be fast with this crazy engines
Gregory
Post by Gregory »
Bill Chase wrote: Wed Apr 19, 2023 6:00 pm
Greg Finnican
Charlotte, NC
Give me a call.
Greg Finnican
704 408-7356
