Holley 3310 venturi cast ring
Justa1time
Post by Justa1time »
Good Morning,
I am going through this holley 3310-6. What is the significance of the ring shown in the photograph? Is it wise to remove this ring and blend it smooth?
Thanks,
Bryan
Walter R. Malik
Re: Holley 3310 venturi cast ring
Post by Walter R. Malik »
Justa1time wrote: Sat Apr 15, 2023 6:06 am Good Morning,
Thanks,
Bryan
If you are after max air flow, then remove it.
If you wish to have the carburetor work correctly without other modification, leave it there.
