23° tunnel rammed 421 sbc dyno
54chevkiwi
Post by 54chevkiwi »
Engine is at the shop waiting to be dynoed...
As a refresher, there are pics of flow numbers and the cam specs. Cam was degreed to intake valve open and the ICL fell on 110
Braswell 4760 carbs, I can't remember the sizes (can update) but I'm pretty sure they're their version of 750s..
SHP block, .904 bam solid rollers, 11.3:1 compression, 93 octane pump gas, 1.7/1.6 rockers
Anyone want to guess at a power number?
I have a number in mind. Based on the goal of this cam, it's not a power number that even needs a tunnel ram and braswells to get lol, but the goal was to have enough power and reliability to successfully complete-not necessarily place in-a drag week, without incident. That's my goal at this stage, just to successfully complete one. I already have Jones specs for a "watch out" HP cam to go in next.
54chevkiwi
Re: 23° tunnel rammed 421 sbc dyno
Sorry the cam one is sideways
54chevkiwi
Catch can will mount to coil over shock tower on that side so there he hangs for the pic
54chevkiwi
My home done valve spring oilers... Send oil to the front distributor drive, tap turns off the covers for lash adjustment
steve cowan
Post by steve cowan »
590 ft/ lbs @ 5300rpm
786 hp @ 7000rpm
sbcMark
Post by sbcMark »
730hp/6800rpm
575tq/5500rpm
54chevkiwi
If it makes anywhere near that, i'll vomit lol
KnightEngines
Post by KnightEngines »
ICL is too far retarded!
Wind it forward at least 4 degrees.
Moparboy440
Post by Moparboy440 »
719 hp @ 6700rpm
607 ft/lbs @ 5500rpm
Elroy
Post by Elroy »
What heads? I don't see where its listed
af2
Post by af2 »
54chevkiwi wrote: Sun May 07, 2023 5:42 pm If it makes anywhere near that, i'll vomit lol
Why?
GURU is only a name.
54chevkiwi
af2 wrote: Mon May 08, 2023 3:38 pm
Why?
I dunno, I'm kind of expecting 720. I think it'll definitely go 720, but won't be 750, so I think if it goes that high I'll plotz ....
54chevkiwi
Elroy wrote: Mon May 08, 2023 3:33 pm What heads? I don't see where its listed
My bad, I guess that info cut off the flow sheet. Eric Weingartners 248cc wing dragon slayers, 2.125/1.575 valves, 2.8 CSA
af2
Post by af2 »
Oh boy should be impressed!
Post by F-BIRD'88 »
The camshaft is way too short. It will run vrry nicely but not up to your goal using that cam. These is a lot more in it with the right camshaft.
