Whatever happened to tall-deck 427" BBCs?
Walter R. Malik
Re: Whatever happened to tall-deck 427" BBCs?
Post by Walter R. Malik »
PackardV8 wrote: Sat Aug 05, 2023 11:15 am
VMC wrote: Sat Aug 05, 2023 8:11 am I know everyone screams from the top of their lungs that the rod ratio is all wrong and that it'll wear out the cylinder walls in no time, and that the skirts come too far out the bottom of the bores, etc.,
For true. Same but different, when I was building SBFs, I was very skeptical of the 347" being durable. Now, any kid with a checkbook can build more SBF power with a 347" than any 289"/302" we/Shelby/Roush ever dreamed of.
Scott Main built a Ford 410 inch engine with an 8.2" deck block for the Engine Masters contest about 18 years ago.
Walter R. Malik wrote: Sat Aug 05, 2023 12:31 pmScott Main built a Ford 410 inch engine with an 8.2" deck block for the Engine Masters contest about 18 years ago.
We marveled at that build, but Scott had to admit the cylinder walls were paper thin. even he said it was a dyno queen only.
Walter R. Malik
PackardV8 wrote: Sat Aug 05, 2023 4:52 pm
Well, just go a bit smaller than a 4.250" bore on that siamesed Dart block; the engine will still be plenty big. LOL
ClassicComp
Post by ClassicComp »
Walter did you use a custom connecting rod for the bbc build?
If not and you don’t mind what did you use?
results speak for themselves
Walter R. Malik
ClassicComp wrote: Wed Aug 09, 2023 9:32 am Walter did you use a custom connecting rod for the bbc build?
OLIVER custom.
ClassicComp
Jack vines check your messages
