Newly fired BBC...exhaust shaking on left bank only
Freddie
Post by Freddie »
Right side exhaust pipe at rear of car smooth stable and unmoved
Left side wobbles all over the place
All hangers checked and all good.
I also have a "whistle" coming from the left hand side exhaust, it increases as RPM increases
I'm thinking a leak / gap in header collector to exhaust flange gasket or I haven't sealed the pipes well enough up to the heads...
any other thoughts ?
barnym17
Re: Newly fired BBC...exhaust shaking on left bank only
Post by barnym17 »
Is the engine missfiring or running well?
BillK
Post by BillK »
Both sides are connected to the same engine. If one side is solid and the other side moves around it sound to me like the left side is not supported correctly somewhere. You need somebody to grab hold of the left pipe and shake it around while you look to see where it is loose.
54chevkiwi
Post by 54chevkiwi »
Left engine mount bad...?
Freddie
Post by Freddie »
Solid mounts - they are all good. It does have a slight misfire every 20 secs or so that I am trying to track down. Yeah I agree same engine how can it be engine related, esp when the engine (at idle) is basically unmoved. more to look into...I need to get under it
69427
Post by 69427 »
It doesn't by chance have a 4-7 swap cam?
1.34 9.42 @ 142.41 / 1.28 5.96 @ 115.00 @ #3251 Better in 2023
427 BBC by S&S Speed Center, AFD, Enderle MFI by Spud Miller
Sepanek Racing T400, Dynamic converter, Autoweld, Santhuff, Smith Racecraft,
Dick Fords Body Shop, Trackside Products,
mag2555
Post by mag2555 »
If you crank it with the spark killed is the cranking rpm steady, or does it speed up going by a particular cylinder?
In-Tech
Post by In-Tech »
I'd throw a $1 bet the ex valve to guide clearance is too tight.
-Carl
Freddie
Post by Freddie »
OK so exhaust fixed. It was a hanger. looked OK on basic inspection I went all over them with the car running and one was cracked (metal part) and when still it reseated and looked OK.
Now to figure out the whistle. Definitely sounds inside the engine. I might pull the carb and freshen it up and ensure there are no vac leaks. Might be a pin hole leak in a casket or something like that
