Damage wrist pin?
Damage wrist pin?
What would cause this? PBM Piston PBMPF4040550
Only pin with this issue.
Re: Damage wrist pin?
Just plain bad metallurgy?
If that’s pitting then I would expect to see those small particles loaded into the wrist pin bore.
Is that the case?
That looks to be the area on the pin where the oil ring groove has a drain hole going to.
Was any polishing or rework done to the pistons and that one drain hole not cleaned out fully?
Is that the case?
Looks like corrosion. Most of PBM's pistons are Mahle and I have not seen anything like that.
Looks like corrosion. Most of PBM's pistons are Mahle and I have not seen anything like that. Any chance it was like that from new ?
Reminds me of this!
Oxygen, hydrogen, sulfur, sodium and phosphorous walk in to a bar……..
“OH SNaP” says the bartender!!!
1 of 16?
Sweat during assembly without lube.
DNA?
Really surprised that pin's bore isn't nasty!
DNA?
Heat treatment scale that possibly did not clean up in the centerless grinding process.
