Helmers Camaro was one of the nicest First Gen Super Stockers I have ever seen. It was really nice!maxracesoftware wrote: ↑Fri Jun 30, 2023 5:26 pm Dave Layer 's SuperStock Heads were my greatest competition in those Days
honest true Story : ( according to Danny Helmer Sr. )
here's what Danny Helmer Sr. called me up directly from a DragStrip ( not in Division 4 ) i can't remember the NHRA Division ( i think it was in yours )
Danny had just re-set the NHRA Record 9.67 ET , and Danny said they made Danny tear-down for Legal check
NHRA Tech Guy took his Cylinder Head + along with David Layer into small building closed the Door
and did not let Danny go in with them ... Danny said they are still in there , been in there 15-20 minutes , i'll call you back with results !
Danny called me back again and said NHRA Tech Guy said your Legal and Cylinder CC's at 165 cc
Danny told the Tech Guy "ain't that whats it supposed to be"
if you knew Danny , he said things like a Comedian , but it was "Dry Humor"
its just in the way or style he said things !
by Luck, the NHRA Guy CC's the largest Intake Port volume i had out those #041X castings
i had 164.9 CC on that Intake Port the Tech CC'd ... the average of all the rest were 163.9 Intake Port CC's
that was a very close Call
the very 1st pair of Heads i did for Danny Helmer / Patterson Racing
were #462 castings , the Legal Intake Port CC's were 162.0cc max
i made them 157cc Intake Ports with Epoxy just to see what hi-velocity + good Flow CFM would do
on a 4-Speed Manual Trans Car ... Danny set his 1st Record at 9.93 ET with those #462 Heads
... by then i had just finished a series of Dyno tests with Jimmy Faul SBC SS/IA engine
with #462 at 162.0 Legal Limit -VS- #041X with 165.0 cc Legal Limit
the #041X Heads with just 3.0cc more i could use to enlarge way too fast local Port areas
made more HP than #462's + much faster down the Dragstrip too !
Division 4 Tech Guy Mr. Red Anderson told me my Heads were the most Legal he's seen so far !
i never acid-ported any of my Heads , never had to weld Exhaust Ports to make them Flow either .
SuperStock 461X 041X Heads and Dyno tests
Re: SuperStock 461X 041X Heads and Dyno tests
Here is what I had for a 1.94 Layer on a 4.000 bore..
I remember in the early 70's "Modified Production" days we used to look for the 461X heads because we could get the intake ports as big as around 198 cc's and the non-X heads would break through at just under 190cc's.
We didn't have a flow bench or a dyno back then but. the ET difference was almost 2 tenths; (that's a lot of power difference).
Thanks for the post with the pictures, what a great body of work you've done over the years!! Harold Bettes always regarded you as a excellent thinker and getting it done type of person. Invaluable in information, thanks! Its worth mentioning "Red Anderson" came up in discussions quite often as well, known for saying "what are you trying to do here".
It is an honor to be included with this group! I still have plenty to learn, my 041's only flow 275 cfm! Thank you!maxracesoftware wrote: ↑Fri Jun 30, 2023 6:56 pm "Shout out to all these Head Porters and their YouTube Videos"
Eric Weingartner
Double Hump SBC Flow Test
https://www.youtube.com/watch?v=T_SAr2Dju8Y
Speier Racing Heads
https://www.youtube.com/watch?v=MaIPvX3VlQU
https://www.youtube.com/watch?v=5rsj0K1QmkU
The MBE Group / Jimmy Biggs
https://www.youtube.com/@jimmybiggs4674/videos
David Vizard
https://www.youtube.com/user/DavidVizard/videos
i purchased this David Vizard brand new Book early on, so very many years ago,
its mostly worn out now ... falling apart , i read so many times way back then !
i think it might be David Vizard's 1st Book ???
Charles Servedio cylinder head porting & flowbench
https://www.youtube.com/channel/UCN-tYC ... o7w/videos
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
The dyno operator here local to me told me you just did a set of GT 40 heads for his brother.
Small world... thanks!
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Here are some pics of a Layer 041. Clearly see the crack!
Larry, Joesph Elias and myself submitted a Pro-Filer porters core to NHRA. That and a list of shortcomings of the Edelbrock aluminum.
Here is the response. From that date, still no Edelbrock castings available.
In building some Super Stock small block Chevy stuff in 20+ years past, we would get the same heads done by two different places ... Dave Layer intake ports and Steve Sanchez exhaust ports; (no brazing).maxracesoftware wrote: ↑Fri Jun 30, 2023 5:26 pm Dave Layer 's SuperStock Heads were my greatest competition in those Days
Those engines always made great power.
Comments like that from people such as yourself inspire me to continue on with my own 23 degree junk!SpeierRacingHeads wrote: ↑Fri Jun 30, 2023 4:35 pm Come on Larry, why you messin with that old technology?? It's 23 degree junk.. LOL!
The people who think and say that are complete idiots. They have zero idea what this stuff is all about. zero!
Long live the SBC.
Kevin
Eric Weingartner
Sadly, Mr. Weingartner has been chased away by one of our resident trolls...
Kevin
i just found :
Danny Helmer's 1st NHRA Record ET Slip Data
1966 Nova with 4-Speed manual transmission
#462 castings
3170 Lbs w/Driver
1.390
4.050
6.305
108.21
8.270
9.935
135.19
Danny Helmer NHRA SS/H SuperStock Class 2004
SBC Chevy engine with Q-Jet Carb
041x Cylinder heads with 1.940/1.500 Valves
Edelbrock Victor E intake
3170 Lbs w/Driver
---DragStrip Times---
60 Ft= 1.318
330 Ft= 3.902
660 Ft= 6.111 - 110.916 MPH
1000 Ft= 8.028
1320 Ft= 9.659 - 137.575 MPH NHRA Record
i remember the 9.67 ET Record .. i need to also find that Data
i have a Picture of Danny's 1966 Nova somewhere , i need to find it !
Danny Helmer's 1967 Camaro SS/I
#041X Heads
i'll search for the NHRA Record he set in SS/I Class
i think he also set 2 different Records with the 1967 Camaro
the Flowbench Sheet was super easy to find !
his Dyno Sheets are in plastic containers, might take a while to locate them ??
#462 castings
3170 Lbs w/Driver
1.390
4.050
6.305
108.21
8.270
9.935
135.19
3170 Lbs w/Driver
60 Ft= 1.318
330 Ft= 3.902
1000 Ft= 8.028
#041X Heads
viewtopic.php?p=949029#p949029
also a Data Correction :
i discovered Danny's real 1st NHRA Record was with my #462 castings at 157 CC Int Port Vol CC's
SS/I Class 1966 Nova 338cid 157cc Intake Port Volume CC's
10.07 ET at 131.20 MPH <--real 1st Record Run
1.35 to 1.39 60Ft range
Ford 9" 6.20 gears 3.08/1.91/1.38,1.00 Trans Ratios 99" Tire Rollout 14 wide on 14 rims
Alan Patterson's Dyno 600 RPM/SEC
405 to 413 Peak TQ Range
527 to 528 Peak Hp Range <--- 157cc at 600 RPM/SEC
also discovered i used new A1 Intake and Exhaust Valve supplied by Helmer
i think at that time A1 Trans/Converters were selling Valves ????
Edit/Corrections this was "after" they sent Heads back to me
and i removed some Epoxy out of Intake Ports to get 160.5cc to 161.5cc range from 157cc
and also 30.0 Intake Valve BackCut Angle on A1 Valves
Danny Helmer's 1st NHRA Record ET Slip Data <--- correction this was really Danny's 2nd Record
#462 castings at 160.5cc to 161.5cc range + 30deg Intake Valve Backcuts A1 Valves
3170 Lbs w/Driver SS/H
1.390
4.050
6.305
108.21
8.270
9.935
135.19
this is with SBC338cid ( 327cid to NHRA max limit = 338cid )
#462 castings ( NHRA Legal Intake Port max CC Volume = 162.0cc )
Ported by Meaux Racing Heads
this is the same 338cid in 1966 Nova in SS/H Class
some additional Data from Helmer phone call :
6-Finger 9.000" Disc Premier Clutch setup
2.000" open Q-Jet adapter/Carb Spacer
Ron's Porting Sevice 4x4 Intake Manifold
9.0 Lbs Porche Driver + Passenger Seats
Lamb Front and Rear Disc Brakes
SS/H can be 3120 Lbs with 338cid SBC ???
here's another Run Helmer ran in Houston, Texas 3-6-93 National Event
1966 Nova SS/H
SBC 338cid w/#462 castings Ported by Meaux changed to 160.5cc to 161.5cc 30deg Int Backcut
1.328
3.968
6.211
108.55
8.172
9.847
133.63 ... looks like he let-off at 1320 MPH trap, maybe didn't want to hurt Class Index ???
Danny also said he backed-to-back Dyno tested
Ron's Porting Service Edelbrock 4x4 Manifold -VS- Wilson's Manifold
Wilson Manifold 7000RPM to 8000RPM = 557 average HP
Ron's Manifold 7000RPM to 8000RPM = 551 average HP
this was on Salina's Engine Service SF-901 Dyno at 300 RPM/SEc Test Rate ( Salina, Kansas 67401 )
Stahl 2-Step Headers 1.750, 1.875 3.500 Collectors
Jericho 4-Speed Trans 3.08, 1.91, 1.38, 1.00 Ratios
6.20 Rear Gears with 99.0"x14.0" width Rollout Slicks on 14.0" wide Rims
Gear Shifts = around 7800 RPM
VP C-12 Race Gas
Sig Erson Solid Roller Cam specs : 278/284 107 LSA
tested Cam on Intake CL from 103.8 IntCL to 110.8 IntCL
with Cam on 103.8 IntCL Helmer had 0.120/0.120" Valve-to-Piston clearance at zero Lash
with Cam on 110.8 IntCL Helmer had 0.113" Exh Valve-to-Piston clearance zero Lash
best Dyno test HP was with 0.032/0.032 Valve Lash and 36.0 BTDC Ignition advance
with Cam straight up on 107.0 InCL was best overall TQ and HP Curve
... one test w/ Cam retard to 109.0 IntCL was 2nd best overall TQ and HP Curve
... another Dyno test with Cam on 104.0 IntCL was worst result
i only have the Dyno Sheet from the Wilson Intake Manifold test
Peak TQ = 435.0 at 6500 RPM at 300 RPM/SEc Test Rate
Peak HP = 556.4 at 7900 RPM at 300 RPM/SEc Test Rate
.... this is supposed to be Test with Cam on 109.0 IntCL retarded 2.0 degrees from 107.0 IntCl
more Corrections :
1966 Nova with 4-Speed manual transmission <--- this really was 1967 Camaro running in SS/H
3170 Lbs w/Driver
60 Ft= 1.318
330 Ft= 3.902
1000 Ft= 8.028
sorry for all these Corrections ,
i'm having to look thru a ton of old Dyno Sheets and on Flow Sheets as best i can
i'm writing the Data down as quick as i can as Danny's telling it to me in Phone Calls
and some of my hand writing is hard to read , as i'm doing it as quick as i can !
I told Danny to send me ET Slips ... never got them ... i only got 1 Dyno Sheet from Salina Engine Service
will Post the Salina Engine Service Dyno test shortly after i Scan it
1.390
4.050
6.305
108.21
8.270
9.935
135.19
1966 Nova SS/H
1.328
3.968
6.211
108.55
8.172
9.847
VP C-12 Race Gas
more Corrections :
3170 Lbs w/Driver
60 Ft= 1.318
330 Ft= 3.902
1000 Ft= 8.028
Corrected HP numbers + Sig Erson Cam Card
UnCorrected Raw HP numbers + Sig Erson Cam Card
