SuperStock 461X 041X Heads and Dyno tests
Re: SuperStock 461X 041X Heads and Dyno tests
Page 2 about 1/3 of the way down, there is a picture of an exhaust port with expoy in it. I have a set of heads somebody hacked the exhaust port at the header flange. What epxoy are you using ?
Furnace cement isn't it ?
No epoxy there ... instead that's Brazing , welding Brass to bottom of Exhaust Ports
First set I saw brazed up were my dad's heads that he got from Troupi and Kling back in 79. Ton of work
Larry
I just bought a brand new set of 292 castings, I'd very much like to send them your way!
Email me all the Engine details for those #292 Turbo castings
those #461X Heads are much better looking now , than the Pics above are in previous Posts !
i went to 320-Grit finish in Bowls and Chambers instead of wornout 120-Grit Roll as in Pics
reason : for these old cast-iron Heads to help stop a crack from forming
plus some little rust spots kept popping up after polishing , and the 320-Grit finish seems to have stopped that so far !
Ports are still 120-Grit finish so far
i'll Post new Pics later on
WOW, that Z28 intake really kills the flow! I cut the divider down a bit on one last summer for a LT1 restoration build and it picked up some power.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
CPMotorworks,Inc.
My SBC air Gap with the divider cut down was quicker and just as fast as my 300-25 was in testing. I am sure with more compression and stuff it would have been the other way arounds though. Nice work Maxrace.
