SuperStock 461X 041X Heads and Dyno tests
Tom68
Re: SuperStock 461X 041X Heads and Dyno tests
Post by Tom68 »
Dented (to clear the valve train) factory sheetmetal covers look tuff.
maxracesoftware
Post by maxracesoftware »
maxracesoftware wrote: Tue Jul 11, 2023 4:16 pm i just talked with Chris at C and S Performance in Baton Rouge , LA
its a "numbers matching Engine" as far as Engine parts,
but its not going to be a "numbers matching" Car
by coincidence, Chris is actually in the process of assembling the Engine today when i called !
( not a 350cid )
BES # 186 castings
its a 302cid Z28 Engine original Cross-Ram Intake Manifold with 2 Holley Carbs numbers matching
however, Chris is going to use 2 new EFI Holley Carbs instead , along with new Hydraulic Roller Cam,
the 1968 Camaro Z28 4-Speed manual trans will be a Street driven Car , Chris already has changed rear gears to 3.73 ratio
... Chris said its taken a long time to get this far with this Car restoration ! longer than he expected !
this is not the 1969 Camaro Z28 Cross-Ram Manifold version that Chris at C & S Performance is restoring ,
instead this is another 1969 Camaro Z28 Single-Holley Carb numbers-matching that Woody Gary just emailed me .
Woody Gary quote :
"Here is a pic I took in 2015 just after I finished the car in Biloxi.
Check out the Houndstooth interior!!"
Woody Gary quote :
"2018 Gators B/SA Class Elim
2nd round of class when I had the HP hit on my combination. I went 1.21 under the B/SA
index . I was extremely late on the starting line with a .121 reaction and Mustang had a
good light. I was catching him and closed the gap up to 2' at the end. Didn't think I was
going to hit the HP. I left Gainesville dejected LOL.."
MaxRace Software
VMC
Post by VMC »
maxracesoftware wrote: Sun Jul 16, 2023 10:11 pm VMC ,
awesome great Pictures .... Thanks for Posting !!!
Chris likes to use +0.100" Longer Intake and Exhaust Valves
i forgot to measure the Valve lengths when i Flow tested the Heads
.... so maybe +0.100" longer valves , along with Roller Rockers which are 1.60/1.60 Ratios , instead of 1.5/1.5,
made it very hard to fit or find a Valve Cover that can fit .
Chris is using a Hydraulic Roller in that engine .
Another factor is : they probably want to keep original Z28 302 Valve Covers
exactly like OEM shape , and also those 302 OEM Covers would never clear
+0.100" longer valves , along with Roller Rockers .
They probably also do not want to do anything to the Z28 OEM Cross-Ram Manifold either !
Once i get some Engine Pics , i'll post them
Larry;
If memory serves, stacking two of the double-thick valve cover gaskets on each side raises the valve covers up considerably--whereas the OEM replacement style Fel-Pro 17930 gaskets are only .156" thick (each), the Edelbrock 7548's are .250" thick (each) and the Fel-Pro 1604's are .313" thick (each).
I have T&D shaft rockers on my 302 (the one you re-did the heads on for me that I still need to get back to the dyno again after the Jesel belt drive failure!), and OEM early "script" stock stamped steel valve covers (such as were used on a `67 Z28) almost clear with stacked extra-thick gaskets.
If one really had their heart set on running stock cast `69 Z28 valve covers with roller rockers, etc., it might actually be do-able with enough gaskets stacked under them lol. :)
As far as any mods to the reproduction crossram intake itself, the only modification I had to make was enlarging the relief at the rear China rail to clear the port for the oil pressure sending unit. The reproduction intake had a bit too much material there and had to be relieved to clear. Other than that, it required absolutely no modifications.
cpmotors
Post by cpmotors »
It's possible to fit Ultra Pro Magnum rockers under the stock Z28 cover with a single .187" gasket...it just takes a bunch of work.. And the only gasket I found to fit the cast cover properly is the MR Gasket 5860.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
maxracesoftware
by cpmotors » Tue Jul 25, 2023 9:34 am
Chris did the very same thing with the Valve Cover gasket before i could tell him what you said !
he also had to mill for clearance on the custom new Valve Covers , to clear the Cross-Ram Manifold Runners
says he has Jesel Rockers on this Engine
MaxRace Software
cpmotors
Post by cpmotors »
maxracesoftware wrote: Sun Jul 30, 2023 8:12 pm
Shaft rockers would be nice, but I had to deal with leaving the drippers in place for these covers as they are '71-72' specific, and customer paid $1k for them.
I milled the rocker rail to make them flat for a good seal and to prevent any odd forces on the covers doing damage to them.
https://www.youtube.com/shorts/eKOI-PoDXso
Pete Graves
CPMotorworks,Inc.
maxracesoftware
Jimmy_Faul_SSIA_Camaro #041X Cylinder Heads
MaxRace Software
maxracesoftware
MaxRace Software
1980RS
Post by 1980RS »
Interesting for sure on the head flow of a 461X head, I've owned 2 sets and sold them both for some good $$$ as guy thought they were the hot ticket for their cars. I know a few people back in the day that were running the X heads on their encono-dragsters, they made great power with them, most likely after porting.
1972ho
Post by 1972ho »
I just have a curious question about the cylinder head intake entrance and why is it built up with clay the way you all do it.What is it’s purpose because I’ve never seen a intake manifold exit that looks like that.Thanks
SpeierRacingHeads
Post by SpeierRacingHeads »
So Larry I know you will appreciate this. This would be the Edelbrock that would replace the 041. This set is for a 350/300hp combo.
While I appreciate the purest, the aluminum head is bigger in volume to be legal.
Speier Racing Heads
Chad Speier
785-623-0963
289nate
Post by 289nate »
I suppose your not allowed to use the W shaped or finned intake port floor. Would be a cool way to have fun with the port while complying with the cc rules.
SpeierRacingHeads
289nate wrote: Fri Apr 12, 2024 11:17 pm I suppose your not allowed to use the W shaped or finned intake port floor. Would be a cool way to have fun with the port while complying with the cc rules.
You can.. I tried it on my first engine.
Speier Racing Heads
Chad Speier
785-623-0963
maxracesoftware
SpeierRacingHeads wrote: Sat Apr 13, 2024 10:46 am
"I tried it on my first engine."
did it gain HP ??
did it lose HP ???
or no difference in HP ??
.... pick one ! :lol:
MaxRace Software
SpeierRacingHeads
maxracesoftware wrote: Sat Apr 13, 2024 2:47 pm
did it gain HP ??
did it lose HP ???
It made 530 torque but peaked early like 6900.
Just couldn't get enough area. I wanted to try it so I did it on mine.
Speier Racing Heads
Chad Speier
785-623-0963
