NEW 360ci TOPLESS OUTLAW - STEEL BLOCK BANDIT ENGINE
Engine # PRE 355
Dart SHP Pro Series block - 4.145 bore,350 mains
Callies 3.335 stroke crank - 350 mains,sj rods
Callies Ultra I beam sj rods
CP 4.145 bore 12.8cc dome pistons -.043-.043-3mm rings
Jesel .937 keyway lifters
Comp Cam 1.949 billet 8620 roller cam
Brodix 233 cnc ported Track 1X heads
2.125 -1.600 titanium valves
Pac 1392R valve springs
Exeldyne tool steel retainers
Jesel 1.60 - 1.55 shaft rockers
Bosch F09CSO sparkplugs
Phantom sparkplug wires
Fabricated aluminum valve covers
Ported Edelbrock 2925 intake
Stewart Stage 3 water pump
ATI balancer
Jones serpentine pulley set
MSD 85501 distributor
MSD crank trigger
Kevco 10 qt wet sump oil pan
14:0 compression
662hp @ 7300rpm
514# @ 6200rpm
Valves - .016 hot
Timing - 36*
$31,500 cash
Pictures & dyno sheet available by email
PHONE: 865-567-6943
EMAIL: terry.marciaburnett@gmail.com
Re: NEW 360ci TOPLESS OUTLAW - STEEL BLOCK BANDIT ENGINE
Pictures for engine.Spark plugs are Bosch F09CS not F09CS0 but I can' t change post.
Dyno sheet
