Highest power exhaust for GSX-R750 L1 2011-2023?
ptuomov
Post by ptuomov »
What's the highest power exhaust for GSX-R750 L1 2011-2023?
The criterion is average power in the 11,000-15,000 rpm range and nothing below that matters. The shape of the torque curve doesn't matter and neither does the ground clearance so no need to do the 1-2&3-4 motorcycle 4-2-1s here.
Put Search Keywords Here
hoffman900
Re: Highest power exhaust for GSX-R750 L1 2011-2023?
Post by hoffman900 »
ptuomov wrote: Sun Sep 24, 2023 5:00 pm What's the highest power exhaust for GSX-R750 L1 2011-2023?
The shape of the torque curve matters for anything used in a vehicle / bike, but if you’re dead set on it:
viewtopic.php?t=31606
Read Clint’s (nitro2) posts
ptuomov
Post by ptuomov »
It’s going to be nice enough no matter what in the 11-15k range, and that’s all that is ever needed with the gear box. 2-6 gears only use 12.5-15k.
That thread never reveals the super duper secret exhaust. What’s the best known exhaust?
ptuomov
Post by ptuomov »
S measuring the engine internals for the 1D simulator:
ptuomov
Post by ptuomov »
I’m thinking that the exhaust port at 31mm is a little small for trying to get the stock exhaust cam to hold up the 150hp+ power for the full 11-15k rpm range.
A pretty exhaust pipe photo here:
hoffman900
ptuomov wrote: Sun Sep 24, 2023 5:58 pm It’s going to be nice enough no matter what in the 11-15k range, and that’s all that is ever needed with the gear box. 2-6 gears only use 12.5-15k.
Pretty sure they were like 4-6” expanding stubs
I think that exhaust port is fine. We’ve put 190whp + through exhaust ports with that same area.
ptuomov
Post by ptuomov »
“I think that exhaust port is fine. We’ve put 190whp + through exhaust ports with that same area.”
I agree with free cams. But how about rules mandated short stock cams?
ptuomov
Post by ptuomov »
Also, what’s the best guess primary length for that rpm range and 4-1 system?
juuhanaa
Post by juuhanaa »
ptuomov wrote: Wed Sep 27, 2023 1:34 pm Also, what’s the best guess primary length for that rpm range and 4-1 system?
-juhana
pcnsd
Post by pcnsd »
Does this system require a muffler? If so... Is there a sound test method and db maximum?
- Paul
ptuomov
Post by ptuomov »
pcnsd wrote: Wed Sep 27, 2023 10:25 pm Does this system require a muffler? If so... Is there a sound test method and db maximum?
No sound test, an object appearing like a muffler required on the pipe, plenty of space and slack weight to make any system appear like an open header to the exhaust flow if sound requirements ever come. So for now it’s to be designed like a fully open header.
ptuomov
Post by ptuomov »
40-45cm wouldn't sound silly for this rpm range.
juuhanaa wrote: Wed Sep 27, 2023 1:53 pm
-juhana
ptuomov
Post by ptuomov »
hoffman900 wrote: Tue Sep 26, 2023 5:06 pm Pretty sure they were like 4-6” expanding stubs
So something like 4 x 4-4.5" or 3 x 5.5-6" primary sections with each section stepping up a pipe size? And then old-F1 style 4-1 collector with a relatively small collector exit pipe diameter?
nitro2
Post by nitro2 »
I think not lol.
High Speed Combustion Pressure Tuning Equipment
TFX Engine Technology Inc.
tfx.engine@yahoo.com
www.tfxengine.com
hoffman900
nitro2 wrote: Tue Oct 03, 2023 2:16 pm
I think not lol.
I tried :lol:
