Building Better 312 Ford Y block Part2: Rotating Assembly Tech
Mummert
Post by Mummert »
Modernize your rotating parts.
https://youtu.be/ctydAgMfj0w
Mummert Y-blocks
Slither
Re: Building Better 312 Ford Y block Part2: Rotating Assembly Tech
Post by Slither »
Wondering if the 5.5lb weight savings on the crank was measured before or after the crank grinding process?
Slither
Mummert
Post by Mummert »
The journal reduction is about a .5lb weight loss. 5 lb difference in cranks with the rod journals the same size.
Mummert Y-blocks
Slither
Post by Slither »
Thanks.
Slither
