Jay Leno -- It's a Dusie!
Kevin Johnson
Post by Kevin Johnson »
Tuner
Re: Jay Leno -- It's a Dusie!
Post by Tuner »
The Dusenberg 4-valve OHC cylinder head combustion chamber looks very much like a DFX Cosworth.
https://www.macsmotorcitygarage.com/ins ... senberg-j/
Ken_Parkman
Post by Ken_Parkman »
Great article - and a mercury crank damper inside the crankcase!
Year late and a dollar short, but I never knew the Dusenberg used quarter-speed cams. Now we know where Bus Schaller got his inspiration.
Kevin Johnson
PackardV8 wrote: Tue Apr 23, 2024 3:09 pm Year late and a dollar short, but I never knew the Dusenberg used quarter-speed cams. Now we know where Bus Schaller got his inspiration.
https://www.hotrodders.com/threads/jim-schaller.70095/ wrote: ... My dad (H.G. "Bus" Schaller) was the inventor of the Double-Lobe cam. I applied for the patent, and we received it in 1959. We developed and sold kits for the 260-327 Chevy engines.
The cam was used by Mickey Thompson in the 1963 Indy 500. He ran the cam in 2 rear-engine cars. One of the cars blew and the other car finished ninth. ...
https://patents.google.com/patent/US2877752A/en?
Tuner
Post by Tuner »
If you are referring to the drawing of the Dusenberg head, look closer, the lobes are described as for cylinders 180 cam degrees, 360 crank degrees, from each other.
Kevin Johnson
Tuner wrote: Tue Apr 23, 2024 4:50 pm
I think that Jack is correct insofar as sighting along the shaft would superimpose the cam lobes and provide an inspiration to a receptive mind. Bus would have known how to achieve it.
frnkeore
Post by frnkeore »
Tuner wrote: Sat Oct 07, 2023 1:22 pm The Dusenberg 4-valve OHC cylinder head combustion chamber looks very much like a DFX Cosworth.
The included angle was a lot narrower on the DFV/DFX
