368 Lincoln Y Block
brechlrl
Re: 368 Lincoln Y Block
Post by brechlrl »
Mercury Mermaid Dayton speed trials in 1957 My recreation. Now resides somewhere in Cali
brechlrl
Post by brechlrl »
Dyno Sheet from a guy in Cali who I consulted on building his engine and supplied a roller cam
frnkeore
Post by frnkeore »
Thank you.
What was the ci, cam timing and engine size on that dyno engine?
brechlrl
Post by brechlrl »
I think it was a .060 over 368. Not sure on cam timing, probably in the 240s @ .050
frnkeore
Post by frnkeore »
Was it a factory 4v intake? What size carb?
frnkeore wrote: Sat Dec 23, 2023 11:20 am Was it a factory 4v intake? What size carb?
IIRC, the car 4-bbls were small bolt pattern for the Holley tea-pot carbs; later Holleys require an adapter. The last truck version had the later Holley bolt pattern, but was considered worse runners for flow.
brechlrl
Post by brechlrl »
He used the aluminum adapter to run an SBC manifold. Probably a Performer RPM or a Victor Jr. 750 Carb. None of the factory manifolds would make that much power.
