Chevy 193 Swirl port Mission Impossible
BLSTIC
Re: Chevy 193 Swirl port Mission Impossible
Post by BLSTIC »
1980RS wrote: Tue Dec 26, 2023 9:51 pm Most impressed with the OP's videos. Would love to see a test with his Vic Jr. tall vs an RPM air gap with the divider cut down. One thing for sure is, just because it's down on the flow with the flow bench doesn't mean it will be bad at the track. Still very very good numbers out of that head.
Yes there's a lot to be said for combustion efficiency making everything that's not max-rpm power better
juuhanaa
Post by juuhanaa »
Im trying to think of what youre leaving out and maybe it has something to do with how the port flows with different manifolds?
Did we see the fuel vaporize before it entered the cylinder? So could we try to put more emphasis on flow instead of mixture motion?
-juhana
Carnut1
Post by Carnut1 »
I actually did both of these tests on my 27th cut port. Performer rpm ported sleeper intake with a 770 Holley and my ported Vic jr. tall with same carb. The Victor was better almost everywhere!
631-816-4911
9:00am - 9:00pm EST
1980RS
Post by 1980RS »
Carnut1 wrote: Wed Dec 27, 2023 8:11 am
Still trying to wrap my head around the Air Gap vs ported Vic Jr. (older one) My Air Gap with the divider cut down was quicker but the Jr. was like 3 mph slower even with re-jetting over the Air Gap + now after borrowing it out to a friend who tested it, his S/V 2925 was better then my Jr. Inc. his stock Jr. at the track, guess mine is a turd. Keep those cool videos coming. :D
juuhanaa
Post by juuhanaa »
I have sprayed more fluid when i didnt believe the results of it keeping suspended with the airflow :)
My shop vac has two filters, i last used it yesterday and it hasnt exploded yet.
-juhana
Schurkey
Post by Schurkey »
Thanks for this thread.
I've been forced against my will to reconsider the "crappy" swirl-port small-block heads. I suppose the next step is to reconsider the "crappy" L29 "Vortec" big-block heads.
1980RS
Post by 1980RS »
Schurkey wrote: Wed Jan 10, 2024 5:26 am Thanks for this thread.
LMAO, My "crappy" L-29 heads went 11.10@118mph. :lol:
Justa1time
Post by Justa1time »
1980 RS. Do you have a thread on your L29? I have two of these engines and have not been able to find much on these except from Richard H.
Charlie, I enjoy your videos on the heads. Keep up the good work! I am really curious what the 193s are capabil of with the 1.94/1.5 combo but ported.
Carnut1
Post by Carnut1 »
Eric posted a video on the Trickflow fuelies. They have a swirl port. I like it. Thanks
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
1.94's will get a bit more work before moving up in valve size. Thanks
631-816-4911
9:00am - 9:00pm EST
Tom68
Post by Tom68 »
Charles, what's you favorite valve guide material for long term street sbc's.
Carnut1
Post by Carnut1 »
For iron I use K line liners. All else maganese bronze. Thanks
631-816-4911
9:00am - 9:00pm EST
Post by F-BIRD'88 »
Fantastic info for the budget street strip racer. As there are tons of these head castings around.
I'd like you to go further and see what happens (noise, flow, velocity etc ) if you play a bit with clay or epoxy on the bowl roof and maybe short side too, to see if you like this port better overall.. You already have plenty of airflow for good power. Can you tweek it with clay(epoxy) to sweeten it to your liking.?
Make the roof nicer.? Reduce the port volume,..
I had the funny feeling you'd get sick of the swirl ramp eventually. Its not bad at all thou with the small ramp you left in last time.
Very interesting. I forgot what size valve is it cut for now.
2.02". , ? 2.05"?
Post by F-BIRD'88 »
Is the slice in the guide boss now creating all the port noise?
1980RS
Post by 1980RS »
Justa1time wrote: Wed Jan 10, 2024 6:38 pm 1980 RS. Do you have a thread on your L29? I have two of these engines and have not been able to find much on these except from Richard H.
I don't think I did on this site. I did my L-29's on a whim to see if they were worth anything over my peanut port heads. They clearly were, I was supposed to get them flowed last winter but the place I was going to have do them was closed that day and I haven't had time to test them as my bottom end expired the day I ran the heads.
