Chevy 193 Swirl port Mission Impossible
PRH
Re: Chevy 193 Swirl port Mission Impossible
Post by PRH »
The head I have here looks to be unmolested from the factory.
The OD of the 45 angle of the valve job measures 1.91”, and the OE valves I took out are 1.94”.
There are also differences in opinion on the claimed chamber volume……76 or 64.
This head, which still has the factory deck finish on it measured 65cc.
I would say this is at least a “medium duty” truck head, with its hardened exhaust seat insert and 3/8” stem exhaust valves.
juuhanaa
Post by juuhanaa »
Could it be that there are two sizes of chambers, which possible explain the difference in flow numbers?
And Charlie; Have you tried a different size bore adapter to see if it is sensitive like the chamber might be?
-juhana
Tuner
Post by Tuner »
:hello2: quote="Bob Hollinshead" post_id=535837 time=1422449129 user_id=6637
Wed Jan 28, 2015 4:45 am
From another thread on swirl ports: All I did was knock the casting flash off the intake, reworked the intake bowl area and swirl ramp (swirl ram is still in place), then reworked the exhaust like you would any small block head. I also unshrouded and opened up the chambers slightly around the intake and exhaust valves. The heads still exhibit very strong swirl. While cleaning them I sprayed water into the intake port and recieved an unexpected shower. The swirl port literally threw water out in about a 6' diameter area. The heads were flow benched at 28 in/h20 just like any other head.
Notice how much better the exhaust flow is than the intake considering the intake is through a 1.94" valve and the exhaust a 1.5"
Valve Lift------Intake Flow---------Exhaust Flow
.050--------------35.6----------------------31.0
.100--------------72.4----------------------60.5
.150-------------105.8---------------------87.3
.200-------------133.4--------------------124.2
.250-------------154.1--------------------147.3
.300-------------180.6--------------------171.5
.350-------------195.5--------------------184.7
.400-------------209.3--------------------196.3
.450-------------217.4--------------------203.7
.500-------------224.3--------------------215.6
So how do you cam a motor when the intake flows just about the same as the exhaust? And what's the power capability of the head? 300hp?
HQM383
Post by HQM383 »
Tuner wrote: Mon Dec 18, 2023 3:22 am :hello2: quote="Bob Hollinshead" post_id=535837 time=1422449129 user_id=6637
Sim using above head flow:
3026 Iterator test, testing cam events for peak HP
355ci (4.030" x 3.480")
Compression 10:1 using 93 octane pump gas
high flow dual plane manifold
1.650" headers
Cam specs: int 265* @ .050" exh 250* @ .050". Lift .420" lobes with 1.6 int and 1.5 exh rockers with lash = int .652" exh .608. LSA 118*installed 4* advanced.
Peak HP 525hp @ 6500rpm
As above but testing for peak torque
Cam specs: int 235* @ .050" exh 237* @ .050". Lift .380" lobes with 1.6 rockers and lash = .586 int & exh. LSA 104 advanced 3*
Peak tq 480ft/lb @ 4000rpm
These would be roller due to acceleration rates and lift. They could be refined further but gives an indication where cam would be headed depending on goal of peak tq or peak hp
Tom68
Post by Tom68 »
HQM383 wrote: Mon Dec 18, 2023 5:09 am
1.650" headers
What's the peak torque with the 265 cam ?
HQM383
Post by HQM383 »
Tom68 wrote: Mon Dec 18, 2023 5:19 am
1.650" headers
440ft/lb @ 5500rpm
Carnut1
Post by Carnut1 »
juuhanaa wrote: Mon Dec 18, 2023 1:55 am Could it be that there are two sizes of chambers, which possible explain the difference in flow numbers?
-juhana
I have I will be using a 400 block so I am set to 400 gasket size. It was a few cfm over 350 gasket size. Thanks
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
Carnut1 wrote: Mon Dec 18, 2023 7:57 am
-juhana
Where this is headed. Thanks
631-816-4911
9:00am - 9:00pm EST
juuhanaa
Post by juuhanaa »
Carnut1 wrote: Mon Dec 18, 2023 10:09 am 20231217_191935.jpg
-juhana
Your work truck, of course :)
-juhana
Carnut1
Post by Carnut1 »
I have been thinking of a set for the old work truck...
631-816-4911
9:00am - 9:00pm EST
Post by F-BIRD'88 »
Carnut: Will you be flow testing your heads before you start port modifications to get a baseline?
Carnut1
Post by Carnut1 »
F-BIRD'88 wrote: Tue Dec 19, 2023 12:34 am Carnut: Will you be flow testing your heads before you start port modifications to get a baseline?
Yes, first video of series 1.94/1.5 combo 175 / 125 cfm more or less. Pretty bad!
631-816-4911
9:00am - 9:00pm EST
juuhanaa
Post by juuhanaa »
How much the swirl would change if the manifold runners were like in this Edelbrock Scorpion2 ?
-juhana
Carnut1
Post by Carnut1 »
Alot.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
Intake flows and air speeds as of now. Not a small port 228cc with 100cc bowl!
631-816-4911
9:00am - 9:00pm EST
