Cranking Cylinder Pressure... Tuning Aid or Myth?
I had always thought 225 to 235 was the optimum cranking compression for drag racing engine combos.
Well my current combo 3.875 x 4.165 (422) SBC with SB2.2 heads and 15.25 compression isn't even in the balpark. (160 psi)
Based on the time slip I feel I'm about .03 slow in sixty foot.
Is cylinder pressure a myth or is my thinking correct?
Current cam is 279/291 @ .050 on a 112 LSA installed @ 108
I think it needs to be 110/108 or 108/108
Fuel is C16
Thanks.
Fuel is C16
Thanks.
It's quite a myth. There is a guideline you can use to determine how much
cranking pressure you can expect with cam timing and static compression .
As for tuning: the spark timing, pulse tuning, valve train responce,
breathing characteristics of the motor, etc. can't be reproduced or
analyzed at cranking RPM.
Having read your combo, 160 PSI seems a touch low but nothing to be
concerned about. The intake closing will make a huge deal.
Have you tried advancing the cam a couple of degrees?
P.S. Just out of interest, I had a customer car that jumped ~ 60 PSI
on cranking from removing 10 cc of chamber volume and resetting
the valves. This was a 383 cube engine.
Last edited by Procision-Auto on Tue Jul 03, 2007 9:22 am, edited 1 time in total.
Sorry, I misread part of your post. I see that it's a 112 @ 108 now.Scott Smith wrote:It's already advanced 4, should I go even further?Have you tried advancing the cam a couple of degrees?
With it being on a 112 wouldn't that throw the exhaust off even more?
What type of cam is this? Roller, hyd/solid?
Scott, it's not related to the cranking cylinder pressure but I can tell you the C-16 is not a good fuel for your N/A engine. C-16 is designed for high mechanical heat load (blower) and you will see a power loss for your combination. The VP C-14 or 14Plus would increase performance for you.
Don't fall into the thinking that more octain is always better also. Over octaining an engine will show up as the engine being sorta doggy or unresponsive to tunning.
Blessings...........Ron Clevenger.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
John 14:6
Ron Clevenger
Greezer wrote:So what might that be?Based on the time slip I feel I'm about .03 slow in sixty foot
E.T. and vehicle weight, too.
Total combo???
Greezer
Well I guess that opens up a big can of worms but here goes..
Peak head flow is 418 @ .700
Combustion chamber is 46 cc with a single valve relief flat top piston.
15.22 compression (Yes I CCed every detail)
2600lb Tube chassis door car. 16x33 tires
5.13 gear
1.80 first glide
converter stalls to 7000
Peak head flow is 418 @ .700 (399 @ .800)
Currently shifting @ 7600 and falls to 6950 on the 1-2 shift.
When I shifted @ 7800 I lost a tenth of G force at the top of first over 7600.
ET range has been a best of 5.43 @ 127 with 1200' DA and a 1.22 60'
Worst has been 5.53 @ 125 with a 1.23 60' with 3400' DA
CHipping at 5000, and tried 6000 but only picked up a little react.
Ignition timing has been from 27 to 30. 27 seems to be the best.
Simular combos with smaller cams and alcohol are 60 footing in the mid 1.teen range.
I know this is a sleeping giant when the air gets good but I still feel there is a lot left on the table.
Ron,
I had a long conversation with Jay at VP.
He said 14 plus was just 14 with 2 more grams of lead and was a dirty fuel.
Out of time I'll be back.
Scott take that nitrous fuel out and put some C14 in as mentioned in the above posts.Fuel is C16
Use someone elses cranking compression gauge. I am having a hard time accepting that it is 160pds of cylinder pressure with 422 cubic inches, 15.2 and 279 duration.
If you happen to come out with the same findings than I would have that camshaft cam doctored to determin exactly what it is. You also might want to find out what that core is intended for. There are two offered blocks and the camshafts definately differ.
Last edited by Strange Magic on Tue Jul 03, 2007 11:53 am, edited 1 time in total.
I wouldn't worry much about the cranking pressure. YOu can alter thoseUse someone elses cranking compression gauge. I am having a hard time accepting that it is 160pds of cylinder pressure with 422 cubic inches, 15.2 and 279 duration.
results with valve lash alone..and in the end, you might lose power to satisfy
the reading you see on the gauge.
It's not worth it. If the car traps higher and runs a quicker E.T., don't let
the cranking pressure spin you in circles.
I agree with strange magic. Something is wrong that you are only pumping 160. Should be 240 give or take a little.
Do you have an aluminum block?
Have you tried another gauge?
Any chance valves are too tight?
Are all the cylinders at 160?
Every .010 change in the valve lash should be about 10 lbs pumping compression. If you tighten .010 it should be 150-if you loosen .010 it should be 170. You might try this and see what happens.
I still think you have a faulty gauge. Best of luck - let us know what you find.
compression
I think there is something wrong with 160 PSI also.
Somebody else can check my numbers but with 15.22:1 and a intake closing event of 71.5 degrees you should have 235/240 psi of cranking compression...
Keith
Keith
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
Dart Little M block.Old School wrote:I agree with strange magic. Something is wrong that you are only pumping 160. Should be 240 give or take a little.
I checked 5 cylinders. All were exactly 160 on 5 strokes.
Intake lash is .025 Ex is .027 cold with 1.88/1.80 rockers.
I have another gauge I can try but I think it will read the same.
If it had 235 I would smile like Paris Hilton when she got out of jail.
