Does anyone have a ballpark total weight for these, so I can rough gauge the balance I have already ?
Pistons, pins & rings ...... if it's on the Wiseco site I can't see it
They're a couple of weeks out and time is getting tight
TIA John
Wiseco Red piston weight
Re: Wiseco Red piston weight
On the Summit site in the spec’s listed for this piston they show no weight either.
Shoot them a email or call there tech line come Monday.
I see you are in England and its probably tough to call them. If you cant get in touch with them shoot me the part numbers Monday and I don't mind making a quick phone call.
BillK, thanks .......
Pt. No. is SKU: RED0007X1
RED Series Chevy Small Block Piston Set – 4.135 In. Bore – 1.000 .In CH, -6.60 CC
Cheers, John
Cheers, John
Piston is targeted at 412 grams pin is 105 grams. He said the pistons might vary a few grams depending on the batch\
I didnt ask about the rings but i am doing an LS with a similar ring pack right now and the rings are 28 grams.
Hope this helps
Hope this helps
