Primitive dial Borge gauge
jed
Post by jed »
Any one Remember using one of these.
Re: Primitive dial bore gauge
I have one in the metrology box. Haven't used it in years.
Back in the day, all OEM Shop Manuals had a bore taper specification. Less than .005", for example, it could be re-ringed with original pistons.
Along with the dial bore gauge had to be a bore ridge reamer.
ImageIn the wrong hands, these would do terrible things to the tops of the cylinder bores.
When we shred an old engine, run 100,000 miles with a carburetor, it's not unusual to find .010" ridge at the top of the cylinders, might not clean up with a .030" overbore. Engines built with EFI and a computer run 250,000 will often still show the honing crosshatch; could be rebuilt without a overbore.
engineman1642
Re: Primitive dial Borge gauge
Post by engineman1642 »
I have that exact same one. It was my grandfather's. BC Ames Co Pat July 6 1925
Kevin Johnson
Post by Kevin Johnson »
B. C. Ames Co.
Waltham, MA, U.S.A.
Manufacturer Class: Metal Working Machinery
http://vintagemachinery.org/mfgindex/de ... 2292&tab=7
