Solid roller spring suggestions please
I have an unknown solid roller cam we are going to try in my Son's sbc 377. Cam specs are 298@.020 266@.050 .445 lobe on the intake, 306@.020 268@.050 .420 lobe on the exhaust. Thinking the shift will be at 7500. 11/32 2.08 / 1.6 stainless valves. We have a rev kit. I have no idea what valve springs would good. We have 1.95 of installed height with standard locks. Any thoughts on this? Thanks
Pro question poster.
Re: Solid roller spring suggestions please
Check with Stan Weiss.
I recall he did some work for DV and produced a program that recommended valve springs based on various inputs. Diameter, installed height, seat and nose pressure ,etc. Used a data base of various manufactures products.
- Paul
- mt-engines
Skip the rev kit.. run a PSI DR424 or run a -.050 lock and run a basic HER611 herbert spring and shim it.Bob Hollinshead wrote: ↑Mon Apr 01, 2024 6:46 pm I have an unknown solid roller cam we are going to try in my Son's sbc 377. Cam specs are 298@.020 266@.050 .445 lobe on the intake, 306@.020 268@.050 .420 lobe on the exhaust. Thinking the shift will be at 7500. 11/32 2.08 / 1.6 stainless valves. We have a rev kit. I have no idea what valve springs would good. We have 1.95 of installed height with standard locks. Any thoughts on this? Thanks
I would look through a few cam catalogs online and find cams similar to that and see what they are recommending.
- New Member
On a cam very similar to those specs, I have run PAC-1343 springs at 1.930" installed height.Bob Hollinshead wrote: ↑Mon Apr 01, 2024 6:46 pm I have an unknown solid roller cam we are going to try in my Son's sbc 377. Cam specs are 298@.020 266@.050 .445 lobe on the intake, 306@.020 268@.050 .420 lobe on the exhaust. Thinking the shift will be at 7500. 11/32 2.08 / 1.6 stainless valves. We have a rev kit. I have no idea what valve springs would good. We have 1.95 of installed height with standard locks. Any thoughts on this? Thanks
There are probably several which could fit that bill.
On a similar cam (270 @ .050) but, 1.76 RR (.710 valve lift), Bullet recommended 220/230 seat pressure and 575/620 open.
WRM's 1343 PAC's fit that bill.
Without the rocker ratio, no one can make an intelligent recommendation.
1.5 ratio on intake and exhaust. Mike, also would you take a stab at what a safe valve lash would be? Thanks
I have run the PSI 1277 springs for years and been happy with them.
I just upgraded to a PSI 1.30" diameter spring looking for better stability in the valve train to turn 8000rpm.
The springs are not much more expensive but I had to get a custom set of retainers from xledyne which were expensive because of the 11/32" stem.
If you are doing the full set up might be worth going smaller max life springs to suit.
Steve is that 1.30 spring a dual spring? This is a mostly street deal so we are hoping for some longevity. I was hoping the Rev kit will help. Crower full body lifters.steve cowan wrote: ↑Tue Apr 02, 2024 8:13 pm I have run the PSI 1277 springs for years and been happy with them.
I am using the DR 427 RML spring which is a 1.30" diameter dual spring.Bob Hollinshead wrote: ↑Tue Apr 02, 2024 11:50 pmSteve is that 1.30 spring a dual spring? This is a mostly street deal so we are hoping for some longevity. I was hoping the Rev kit will help. Crower full body lifters.steve cowan wrote: ↑Tue Apr 02, 2024 8:13 pm I have run the PSI 1277 springs for years and been happy with them.
I am a bit shorter on installed height compared to your set-up but should be able to find something for your application.
- New Member
Depending on what the application of this engine and what your goals are, you have a couple options.
If this is going to be a "max effort" kinda deal where you are trying to make as much HP as possible, I would highly suggest looking at the PAC-1427H conical spring.
If this is more of a street engine combo where you are looking for longevity, I would suggest the PAC-1243.
Both springs would want roughly a 1.900 Installed height.
1427H - 1.870 IH
210 seat and 540 open
1243 - 1.900 IH
240 seat and 598 open.
1427H - 1.870 IH
1243 - 1.900 IH
Since there's no way to know how aggressive the lobe profiles are, I would go with the ISKY 9935 springs without the rev-kit, or the ISKY 9915 springs installed at 1.950" with the rev-kit.Bob Hollinshead wrote: ↑Tue Apr 02, 2024 6:43 pm1.5 ratio on intake and exhaust. Mike, also would you take a stab at what a safe valve lash would be? Thanks
Without knowing the lobe profiles, there's no way of knowing what the correct lash is.
I would start with a Hot Lash on .015" to run it in. Then you want to increase the lash in .002" increments, until it gets noisy or hurts the power.
CamKing wrote: ↑Wed Apr 03, 2024 10:27 amSince there's no way to know how aggressive the lobe profiles are, I would go with the ISKY 9935 springs without the rev-kit, or the ISKY 9915 springs installed at 1.950" with the rev-kit.Bob Hollinshead wrote: ↑Tue Apr 02, 2024 6:43 pm1.5 ratio on intake and exhaust. Mike, also would you take a stab at what a safe valve lash would be? Thanks
[/quote
Thanks!
