Sheet metal tunnel ram 2x4 runner angle
On a symmetrical head (Cleveland 351C V8) do you angle the runners (looking from the top) so that the entrances line up under the carbs.
All the symmetrical head sheet metal tunnel ram 2x4 manifolds that I've seen don't have the runners angled inwards towards each other in pairs. Ther runner angle is the same as the port runner angle like Darin makes on his web site
There is about 1" difference to lining up, is it worth angling them in to line up under the carbs V's the miss alignment between the runner and the port. I already have a severe 15° miss alignment looking from the front between the runner and the port to get the lenght I need
2x4 sheet manifold
What carburetors are these, Dominators or 4150s?
The shape under the carb is as important as anything else.
Troy Patterson TMPCarbs.net TMP Carbs
Most probably 650-750's
We ran dominators on a 427SBF 7500rpm 660hp 10.3sec 132mph, then changed to 750's and went 0.01 tenth quicker, so the dominators might be a touch big
This engine is 417Cleve 7500rpm 650hp trying for high 9sec with a lighter car
What shape under the carb should there be, I was just going to have the open entrances .4sq" entrances sharing the bottom(center valley) radius betwen both banks
They do (or did). Same barrel spacing, same big holes, but large body boosters reduce the CFM rating. (..or at least thats how I remember them)RL wrote:Gee I didn't know they make 750Dom, the owner bought some 950's from a swap meet last time cause he's cheap. He bit the bullet and bought some new BG750(not Dom)
I'd run the Dominators. I'd guarantee there was more than a .01 to be had from the Dom's with proper tuning - although, you didn't say what size Doms. Obviously, there is a point where you don't gain any more from additional cfm.
The 750's limit what booster you can run in the carburetor for best results due to the small venturi dia.
Re: sheet metal tunnel ram
Oops! I got it backwards. Sorry.Troy Patterson wrote:I
I've only seen one set. I was mostly impressed by the lovely anodizing treatment. Nothing says power like pink throttle shafts.
Ya, and the one I did for you was pink with polka dots. I didn't care for the fur you wanted on it, but you know, the customer always get it the way he, or she wants! Your secret is safe with meRon E wrote:Oops! I got it backwards. Sorry.Troy Patterson wrote:I
sheet metal tunnel rams
So much of that is in the tune. The trouble with O2's and fuel flow meters is that it doesn't know whether the fuel is flowing into the carb as a result of flooding, or a perfect tune, as long as it happens to be the right number, everyone assumes it's optimal.
The difference in real world performance can be night and day.
To further expand on this, a carb or other modification to an engine could make more "accelerative torque" but show a lower torque / horsepower reading on a step test dyno, yet accelerate the car faster. The big boys (and the thorough) in racing back up dyno testing with on track testing - be it a step test or inertial dyno.
The 750 Dominator has the same metering circuitry, but hardly has the same venturi dimensions - should been tunable.
